Question about iLO 3200 32 in. LCD Television
My 26 inch ILO remote and side panel won't work
My sis was watching a dvd and when it was done she tried to put it back on analog and it wouldn't work we check the batteries and they were good and the side buttons won't work either now. we got the tv end of December so we don't know what to do with it? And the volume won't turn up either.
  • 53 Answers
First off i would have to ask you if when cleaning the tv do you spray cleaner directly on the set ? as this can cause corrosion on the control pad which would also mess up the remote pick up. second i would recomend you un-plug the set for about 10 min to re-set the tv. third the control panel could have gone bad on you these set's do run rather warm.
Posted on Mar 13, 2007
SOURCE:
Just bought the 26 inch with DVD. Put in dvd and it starts .. tried to stop it and eject the dvd, it froze up and won't release the dvd help!!!
Unplug the unit allow it to sit for a secound, then plug it back in. Try your eject button again on the remote and the TV if there is any. If this does not eject after power cycling the TV. My recommendations are if you just bought it take it back.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Remote doesn't work
The # for Tech Support is 1-800-428-1105 Monday-Fri. 8:30-9PM EST
Sep 01, 2008 | iLO 2600 Television
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
ILO TV REMOTE CONTROL MISSING
Go to this webpage.
Here you can buy the original remote contol for your TV
http://www.remotes-express.com/Ilo/ILO2600.html
Jan 12, 2008 | iLO 2600 Television
Ilo 26 inch HD
Are you saying you need a remote and lost it ?
Dec 12, 2007 | iLO 2600 Television
ILO 26 HD TV
We bought one as well, sometimes it comes on and sometimes it don't. I think walmart needs to refund our money. They knew they were a bad deal since they don't even carry them anymore.
Nov 12, 2007 | iLO 2600 Television
Can't get out of digital mode back into analog
My TV just did the same thing.  All you have to do is turn off the tv, unhook your cable antenna, then restart the tv with the antenna unplugged.  Then go to tv menu, and this time turn the digital scan off.  I really hoped this helped someone!
Jul 23, 2007 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
63 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
