FixYa.com
Tags:
Pitney Bowes 9920 Plain Paper Fax
Do I need a seperate telephone line for my fax... (by 3 users)
By Mini Me - usenet poster
Do I need a seperate telephone line for my fax machine?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Feb 27, 2008
USER MANUAL
Comment by Guest, posted on Nov 05, 2007
I have the Samsunf SF-5100 I can fax out but can receive any faxes. The phone rings and on the screen it show tele/fax. What are my options?
Best Solution
posted on Aug 08, 2005
Helpful (85)
Bouncy
Bouncy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
No. Most of the units have a function that will automatically answer a incoming fax, or allow you to screen the call before receiving the fax.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 28, 2007
Not Rated (0)
trickieone
Rank:Guru Guru
Rating: 89%, 197 votes
If you want faxes to work 100 percent, and they are that important. You should use a dedicated fax line.
If your faxes are not that critical, then you can share a phone line.
I never recommend a fax machine on a shared line, if the faxes are important to you.
Comment by trickieone, posted on Dec 05, 2007
FYI on the fax that will fax out but not receive.
One of the problems I see frequently is that the phone line is plugged into the jack that is for an answering machine or an extension phone. Make sure you have those set.
Also, be sure you have several settings turned OFF.
Many people turn ON Junk Fax, blocking, which will block most of your faxes.
Also check to see if Secure Fax is off and delay fax is off.
Another problem is that a mode called ECM ( Error Correction Mode) is turned OFF, you want ECM turned ON.
Most of the time an issue like this, Receiving not sending or sending not receiving is one of these problems.
Check those things out.
There is a set up menu on all fax machines. Make sure somehow one or more of them were not changed.
Also, you may have a memory clear feature, but be warned that if you do a memory clear, be sure to print out your phone books, and setings list. A memory clear will return the fax to its default setting and resolve many issues.
Solution #3
posted on Apr 25, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Most phone companies offer a feature called multiring which distinguishes a incoming fax from an actually call by providing different ring tones. You simply need to order the feature and you will be provided with a additional number for your fax and then program your fax to use the feature (also called distictive ring).
This Problem Also Relates To: HP 1010 Plain Paper Inkjet Fax HP 1050 Plain Paper Inkjet Fax HP 1010 Plain Paper Thermal Fax Panasonic PANAFAX UF-6000 Fax Panasonic DX-2000 Plain Paper Laser Fax Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Panasonic KX-FL511 Plain Paper Laser Fax
Can you Help with these Fax Machines problems?
markovallejo@yahoo.es
Necesito c?digo de acceso para... Answer This...
information about e-mail
how do i know that my mail has... Answer This...
Fax machine "frozen"
Our readout screen says PB#9920... Answer This...
Need name to show w/fax number...
We have gone throught the... Answer This...
fax
I have a all-in-one printer and... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
