Question about Sanyo DP42746 42 in. Plasma Television
What setting do i put my 42 sanyo on 720p 480i
  • 71 Answers
Its automatic.
Posted on Mar 05, 2009
Rca How To Set my RCA LED32B30RQ - 32"from 480i to 720p
Refer its user manual. It must have details, if there is a facility to change the resolution.
May 01, 2013 | Televison & Video
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I need directions....my tv is set on 480i at the moment
The resolution of the TV is set by the source it is being fed with, just like your PC monitor which is set by the PC video card resolution. 480i = 480i display, 720p in = 720p display.
Its your the video source.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 30, 2010 | Televison & Video
720p is putting out signal of 480i or p only
Your Tv has its own settings for high definition.
Look in your manual for appearance setting and turn the tv to 720p high definition.
That should be enough. OH! And make sure your PS3 is set for HD output too! My HD tv downconverts occasionally when the Uverse box shuts off and defaults to low def output.
Feb 03, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
The display only goes between normal and zoom
This is an EDTV capable of 1080i over component cables. It will also display 480p & 720p. Most likely its the video source determing the resolution you are seeing.
Nov 14, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Sanyo DP42746 42 in. Plasma Television Logo
29 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
