Question about Logitech (980408) Wireless Headset
Logitech headset I have a new phone and i lost the manual for the set-up please help me to set-up to my new phone Thanks Patrick
  • 944 Answers
Which model of phone are you needing help with? :)
Posted on Mar 13, 2007
I have a Logitech bluetooth headphone. And I had to buy a new PS3. I threw away the manual to setup the headphones. Can you tell me how to set it up?
Your passcode should be 0000 (four zeros)
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Jan 15, 2010 | Motorola Mobility Logitech Mobile...
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
Jan 17, 2009 | Motorola Mobility H350 Wireless Headset
I have the Logitech ClearChat Pro USB device, and when i plug it in it says "one of the USB devices attached to this computer has malfunctioned and Windows does not recognize it." i dont think the driver...
the headset has possible lost its firmware try on a second pc if the same issue comes up. reboot the pc . if the found new harware wizard comes up for the device. go back to logitech for a warranty credit.
Jan 11, 2009 | Logitech ClearChat Stereo Headset Headset
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 18, 2008 | Motorola Mobility H350 Wireless Headset
Problem wit PS3 headset!
call logitech  3464543200 tell them the problem then he will help u when he ask to go to settings then he will ask u to test it then say it doesnt work then he  will ask for ur billing information such as adress phone number and zip code then he will send u a new one for free in 7 to ten days
i had the same problem what is ur psn id
Jun 12, 2008 | Logitech (980174) Headset
Logitech Bluetooth Wireless Headphones 980397
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/2891/session/L2F2LzEvc2lkL2VvbmE0eGdr
Nov 14, 2007 | Logitech 250 Headset
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
May 08, 2007 | Logitech (980408) Wireless Headset
Manual for siemens HHB-610 Bluetooth
SIEMENS HEAD SET MANUAL TO PAIR YOUR SEMENS HEAD SET TO A NEW PHONE YOU HAVE TO PUT IT IN TO BLUETOOTH SCAN MODE THIS ALOWS YOU TO FIND THE HEAD SET WHENYOU SCAN FOR NEW DEVICES. TO ENTER BLUETOOTH SCAN MODE PRESS (MUTE AND VOL+) AT THE SAME TIME FOR 5-10 SECONDS , THE LED SHOULD NOW BE A SEADY GREEN LIGHT. SCAN FOR BLUETOOTH DEVICES ON YOUR MOBILE YOU WILL FIND HHB 610 SELECT TO PAIR THEN ENTER 0000 AS PASSWORD .YOU ARE NOW READY TO USE. SYSTEM RESET PRESS (MUTE AND PHONE) AT SAME TIME FOR 5-10 SECONDS THE LED WILL FLASH RED/GREEN FOR ABOUT 5 SECONDS SYSTEM HAS NOW RESET.
Feb 12, 2007 | Siemens HHB-610 Wireless Headset
Logitech (980408) Wireless Headset Logo
136 people viewed this question
Top Logitech Radio Communications Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
