Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
LG front load washer has blocked drain line which is located in
The drain access panel on the lower left front of washer. Feels like the drain line is filled with sediment however I do not know how to access the base of the line so that I can disconnect and clean out. No water is coming throught this drain line...however water is flowing out of drain pump filter when I pull this filter out.
  • 640 Answers
Take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Posted on Dec 25, 2008
LG washer will not drain
Open the access door located on the lower left of the front panel. Use the small hose there to drain the water from the washer. Unscrew the knob next to it and pull out the attached filter. Clean out filter and re-assemble. If the filter was clear, replace the water pump motor.
Mar 05, 2011 | Washing Machines
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
HELLO, we washed clothes and the soap would not clear and the clothes were still water logged. Now in trying to fix it, it will not drain, Not sure what to do terri
Drain the water out by using the small hose located behind the access panel on the lower left side of the washer's front panel. After removing water, un-screw the big knob to the right of the hose and pull it out to check for blockage in the filter. If blockage found, remove and re-try cycle. If no blockage found in filter, replace pump motor.
Sep 07, 2010 | LG WM-2277HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Is there a lint trap on there a 2277HS LG washer
yes, underneath lower access panel on front of machine. be sure to drain water 1st via small drain hose.
Jun 12, 2010 | LG WM2277H Front Load Washer
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
May 31, 2010 | LG WM-1832C Front Load Washer
LG front load washer has a drain error message
Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 07, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
Drain hose
This hose can be removed from the rear by removing the access panel. Look to the left and you will see the drain coming down from the condensate duct. Follow it down to the drain assy. While you have it off, check in the opening for lint build up which can block the drain
Jan 21, 2010 | LG WM3431 Front Load Washer / Dryer
Lg washer not draining
On a front loading LG there is an acess panel on the lower left of the front panel. Open that little door and use the small hose to drain out the water left in the machine. (as long as the hose is not plugged with sand) Now, unscrew the big thing next to the hose, which is a filter. Chances are there is something there blocking the flow of water to the pump. If it is clear and still no pump out, you will have to replace the pump motor. (possible impeller loose on motor shaft)
Nov 11, 2009 | Washing Machines
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
704 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
