Question about HP Compaq Presario V2000 Notebook
My Compaq Presario V2000 won't recognize that it has a disk drive
When you look on My Computer, it doesn't show the drive. Also, when you look at the Device Manager part, it shows the drive with an exclamation point inside a yellow triangle. Whe you click on that, it says: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)" What do I do?
    Master:
  • 409 Answers
What drive is that? are you refering to an exterenal USB drive? If so, you will probably find that it does not have enough power. try adding an external power supply or a second usb cable.
Posted on Dec 13, 2008
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
I installed a new hard drive. on the compaq presario v2000. all im getting is realek media error. i went into bios set default. no resolve. tried cd rom first. no help.jumper pin is outter two verticle....
Does the laptop BIOS "see" the new drive? If not the drive must be "Initialised" first, otherwise it will not recognise you have a drive in the bay. Place the drive in a USB caddy and using another laptop or your laptop with the old hard drive in it, select Control Panel and Adminastrative Tools. Select Computer Management, From the side panel select Disk Management to view selected drives. The disk drive that is connected via USB will be there. Click the drive and select initialise then format and select a drive letter. OR
With the new drive in the laptop bay, set the BIOS menu, on your laptop, to use DVD/CD ROM drive as first boot device.
Place your System disk in the drive and boot from the disk.
Follow the instructions, (if any) on the screen and let the new system software initialise and format the new drive.
Hope that helps
Dec 17, 2010 | HP Compaq Presario V2000 Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Drivers for HP Compaq Presario V2000 laptop
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&query=Presario%20V2000%20&dest_page=softwareCategory&tool=softwareCategory
You will find the drivers you need there!
Just select one of the 3 V2000, the one YOU have, then select your OS, download all the drivers you need.
Good luck to you!
Please take a minute to vote
Nic
Jan 30, 2009 | HP Compaq Presario V2000 Notebook
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Presario V2000 will not boot
When your computer starts press f10 to enter the bios ,there you will find the option to reset its setting to default.....
Was this solution helpful .Show your appreciation by rating it.
May 30, 2008 | HP Compaq Presario V2000 Notebook
Compaq v2000
Do u have installed recently, some software?
Try to boot up pressing the F8 button, when the menu appears select the option "Windows in safe mode" if u can boot to windows. View our software installed.
If it is not software try, boot whit the windows installation disk enter to the setup and select the option repair, u will go to a DOS prompted window (all black whit white letters) must appear "c:\"
used the command "chkdsk /f /r" let it run he will try to find any problem in the disk.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
249 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
