Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Thin twin washer & dryer LT5000XS
The problem is that the dryer does not work at all. It has power and the door switch is fine. The blower duct was completely filled with lint but I cleaned it. There looks to be a sensor on the duct along with one on the heating element duct. Everything else looks to be okay but nothing happens when I try and start the dryer.
  • Anonymous Dec 13, 2007
    thin twin dryer worked fine yesterday, today, it does not work - the start button won't start the dryer, even though it has not run all day.
  • cmanmcmack Dec 28, 2007
    My dryer just stopped working. everything seems to be fine, eccpt the dryer does not work!!
    Novelist:
  • 116 Answers
The lint obstruction possibly caused the high limit thermo to fail. It is designed to prevent the machine from running if it gets too hot. It should be the one at the top of the drier stack. the one on the element needs to be checked for proper operation as well. this can be done with a multimeter. Be sure to unplug your machine before checking as there will be power at the connection points.
Posted on Mar 14, 2007
My whirlpool thin twin washer stopped working. The dryer still runs but the washer does not.
Shut elect breaker off and back on. At elect panel . Sometimes braker trips one side and stays on the other hard to tell the diff.
220. One must be on and the other off. Although they are attached . Make sure door is making contact with switch
Feb 16, 2015 | Whirlpool Washing Machines
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Dryer not working on Whirlpool Thin Twin
Could you check that model number again?Could you please describe the problem you are having?
Does the dryer run at all?
Check the door switch. When you push and release it you should hear a click. If not, replace with a new switch.
Oct 17, 2012 | Whirlpool LTE5243DQ Combination...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Dryer qquite working.
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Dryers
Whirlpool thin twin problem
First be sure you're getting power to the motor this could cause both problems. If getting power then
sounds like you have 2 problems.
Dryer
On the heating problem be sure you have 220 volts at the power block, check the heating element , thermostats & high temp cutoff with an ohmmeter. Also check the centrifical switch on the motor it keeps the heat off for safety till the motor is up to speed so the fan is working.
Washer
Check lid switch some machines won't do anything but fill with the lid open . To check lid switch push the the switch down with a small screwdriver. If switch is ok check the coupler between the motor & transmission it can cause no agitate or spin. If all these are ok you may have a transmission problem. Last resort may be timer or wireing.
Nov 20, 2017 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
518 people viewed this question
Sal De
Marvin
Marvin
jimorris77
