Question about iLO 2600 Television
Stereo/mono on iLo 42 screen tv
This is the third tv this has happened on, all different brands. In the upper left corner the words mono and stereo sometimes alternate sometimes together with a /. I have a seperate sound system hooked up and sometimes when both words are on, I get a loud crackling sound. Usually it stops when the words go away,but once I had to turn off the sound system. Anyone know how to get rid of this? Thank you. airmac19
  • jtsharp1 Aug 31, 2008
    The mono/stereo prompt appears in the left corner we the tv is turned on.
I have encountered the same problem. I have looked through the menu at least a hundred times to find an answer, but the only thing that I have been able to come up with is to push the MTS button on the remote.
Posted on Apr 05, 2007
SOURCE:
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
No audio on only some stations
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Oct 29, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Mono/stereo keeps flashing on my TV screen. How do I fix it?
so for us not using cable for this, what do we do? even plugging a game console into this plug will have same results. keeps switching from mono to stereo making the sound stutter. why does the TV get to decide on its own? who thought of that? is there a setting to choose for it so it doesnt have to bother?
Oct 07, 2009 | Toymax Viore 42 in. Plasma TV
Mono/Stereo Problem
i got the same freakin problem if you find out canyou e mail me the prob rl5312@comcast.net il do the same if i find out first thanks..............
Jan 15, 2009 | iLO 3200 32 in. LCD Television
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 in. iLo
If your TV is connected to a Comcast cable box that has a volume control on it with its on screen volume at the top of the picture. Turn it up until the word "stereo" appears and then only use the TV's volume control. This should fix the problem and allow you to enjoy stereo audio.
Jun 05, 2007 | iLO 3200 32 in. LCD Television
Mono/stereo flashes in upper left tv
The mono/stereo is an indicator of the audio signal that the TV is outputing. Like most car radios, they have an indicator that tells you when a station in coming in clear, which may be just an LED or a light. When the signal is weak or when your on a non-stereo station the indicator will not be on. What signal are you providing to the TV? Cable, OTA, STB output??? low RF signal level could be the cause for this.
Mar 18, 2007 | iLO 3200 32 in. LCD Television
32" widescreen flat ilo tv
I have a 32" Initial which is an ILO with a name change. All I can do is turn it on and off. The volume and menu settings will not work. I have had it for about two months and now I am going to take it back to WalMart. The picture quality is great but it sucks that I can't change the volume or settings. I guess Sony will get my business now.
Feb 05, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
131 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
