Question about Car Audio & Video
Wiring car amp up
I have a 4 channel amp with 2 prs car speakers
the 1 end has the front/back speaker conections,also the gnd-rem -and b+
the 1 im not sure of is the -rem ? where does it go ?
other end has the low input conections,also the input level buttons.
its the 2 white and 2 red phono [ low inputs ] im not sure of as i only have to phono leads to get to radio head ?
advice please. gh.
  • saroct Apr 11, 2009
    not sure what or how to hook up power to car amp do iconnect it to car stereo power or to battery a wire diagram would be so helpful sombody please thanks
  • 328 Answers
The rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Posted on Dec 15, 2008
Wiring diagram for sony xplod amp and how to bridge one
if you have the model number handy i can tell you
but most sonys are marked like this ..
+12v goes directly to the + termanl on the battry
GND goes to a solid metal object on the car (ground)
REM remote turnon goes to the remote turn on from your headunit
unbridged speaker outputs
+L positve left speaker
-L negative left speaker
+R positive right speaker
-R negative right speaker
ok to bridge a amp (must be capabul of doing so) look for a mono switch and set to mono ..
then take the +L channel put it to your subs + and take the -R channel and put it to the - of your sub
also set the cross over switch to LPF if your running bridged for a sub
if that is a bit hard to understand msg back with the model number of the amp and i can get u the orignal manual for the wireing diagram
hope that helps
Jan 26, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Xplod amp
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Sep 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
339 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
