Question about LG LSC121PMA Split System Air Conditioner
I do not have the manual for my LG LS-D2461HS air conditioner
I cannot find the swing button on the remote - does this model have this function?
On your email you have the model down as LSC121PMA - this is not the model I posted my query on, it ws the LG LS-D2461HS, and no my query is not solved.
Posted on Dec 14, 2008
  • 4 Answers
Look at
www.canbysales.com/support.htm
Servicemanuals
2005
sevicemanual LSC091PMA / LSC121PMApma
Posted on Jan 20, 2009
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: http://www.homedepot.com/catalog/pdfimages/d4/d4382c05-2692-4075-a254-fdcdef6dc1fb.pdf . The buttons are the same across the units.
I hope this helps.
Jul 17, 2014 | Soleus Heating & Cooling
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | LG Heating & Cooling
My LG art cool a/c blades in the vent arent swinging (from left to right)as i keep pressing the swing key on the remote.. please help
In some models, there are swing and sweep motors. Swing will work the vent up and down. Sweep or air flow motor will work for louvers left to right. If sweep motor not works replace the motor. If no sweep motor option, you have to direct by manual only. Be care ful, when you are doing manually, switch of the unit. Thanks.
Feb 01, 2011 | LG LSC121PMA Split System Air Conditioner
I cannot find the swing button on my remote for my LG LS-D2461HS
The swing button is usually on the right side of the remote and has three little arrows pointing toward an arc or half circle line with arrow up and down. If you press this once it will go on auto swing, you can wait for the louvre to get to the right position and then press it again to stop in that position. You can also on some models change the left/right airflow direction in the same manner or manually direct the airflow to one side. If all fails, you can gently manually position the louvre up or down.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
Lg artcool 12000btu mirror model
1.check remore battery.if week change it
2.check indoor unit sensar of remote.
3.check sirkit board.
Mar 09, 2008 | LG Art Cool LA1000PR Air Conditioner
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
460 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
