Question about Samsung SC-D353 Mini DV Digital Camcorder
Flip open lcd
There are lines on the lcd screen but there is no picture to see just those lines help
  • Anonymous Dec 30, 2008
    When playing back something I have recorded, I can hear, but there are lines on the viewer - no picture
    Problem Solver:
  • 5 Answers
You need a new lcd ribbon cable this is a common problem
Posted on Feb 03, 2009
I received a Leica Digilux 2 from a relative and i cant seem to see anything thru the viewfinder or the lcd screen. Its just black. Is the shutter not open? I can see all the numbers and settings around...
Open the back of the camera. **** the camera as if you were advancing the film. While looking in the back, push the shutter release, like you were taking a photo.
You see the mirror flip up and glimpse a flash of light as the camera cycles.
If you do not see the mirror flip up and return, the camera needs serious repair..
As for the LED Display, put some new batteries in it.
Feb 12, 2011 | Leica Digilux 2 Digital Camera
My 3 month Motorolla Droid cell phone has some sort of backlight LCD bleeding. The phone functions normally, it's just the screen has grayish/blackish smudge lines going across the screen and you can see...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
I wish you good luck.
Jul 20, 2010 | Motorola Cell Phones
LCD PICTURE UPSIDE DOWN
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
My lcd won't display a picture. it is white with colored lines going across it. If i flip the screen it used to show the picture, but now will just show a blank screen. I'm thinking there is something...
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Jun 30, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Sidekick 3 help
It is just an issue with the lcd. they run about 45 dollars on ebay and are fairly easy to replace.
If you are strapped for cash, try this fix first Fix Sidekick White LCD Screen
If that doesn't help then here is the procedure to replace the lcd.
replacement of the Sidekick 3 LCD flip screen.
And here is a link to the screens on ebay. Buy one with the whole flip assy. It is much easier to replace than the lcd screen itself.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 01, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Flickering picture on lcd screen goes all black
I had/have the same problem. All I do is flip the camera vertical and it works. The screen displays appropriately, I think its some type of lens inside the camera that has came lose and it lines up properly when held vertical. It's a **** one solution, but it worked on mine and you can still take pictures. I would like to be fixed completely but I don't know how to. HELP!
Apr 19, 2008 | Cameras
Samsung SC-D353 Mini DV Digital Camcorder Logo
96 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
