Question about Fisher and Paykel Titan OS301M Electric Single Oven
Bake function takes a long time for temp to increase and keeps dropping down
The Bake function takes ages for the temperature to increase and keeps dropping back down without ever reaching the required temperature. The Fan and Broil functions are working correctly. A service tech called around and insisted it was the electronic control board which was replaced but it made no difference and cost a fortune.
    Top Expert:
  • Fisher and P... Master
  • 9,798 Answers
Check temp sensor and gas pressure
Posted on Dec 23, 2017
    Top Expert:
  • 5,766 Answers
Possibly bake element is bad or control is bad.
Posted on Nov 03, 2017
2 Suggested Answers
  • 69 Answers
SOURCE: my f&p wall oven model number BI602 is not reaching temperature
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer.
Posted on Mar 09, 2010
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Oven warms to desired temp then cools down
Check your bake element. Unually ovens use both bake and broil elements to preheat and just bake element to keep temperature. Your bake element is probably burned out.
Jan 30, 2011 | GE Profile JT912 Electric Single Oven
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
What is the procedure for recalibrating the digital oven temp control for a built-in, dual element electric unit?
Oven will be off, of course.
Depress the Bake button; hold it down for 5-7 seconds.
The default offset of 0 will appear in the numerical display. Or, if the oven has previously been adjusted, you'll see that setting. Use the 'up' or 'down' arrow to adjust the temperature by the desired amount. The adjustments are in increments of 5 degrees F. Maximum adjustment is 35.
Press 'Start' to save the new setting.
I recommend rechecking the oven temp at this time. I expected to see a 25 degree increase, but all I got was 10.
Jan 24, 2010 | Whirlpool Ovens
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Fisher and Paykel Titan OS301M Electric Single Oven Logo
108 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
ray gallant
Ap12
Ap12
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
