Question about LG LSC121PMA Split System Air Conditioner
I cannot find the swing button on my remote for my LG LS-D2461HS
Unfortunately we do not have the manual and it is blowing directly on us - does this model have a swing button? Thank you.
  • 400 Answers
The swing button is usually on the right side of the remote and has three little arrows pointing toward an arc or half circle line with arrow up and down. If you press this once it will go on auto swing, you can wait for the louvre to get to the right position and then press it again to stop in that position. You can also on some models change the left/right airflow direction in the same manner or manually direct the airflow to one side. If all fails, you can gently manually position the louvre up or down.
Posted on Mar 05, 2009
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: . The buttons are the same across the units.
I hope this helps.
Jul 17, 2014 | Soleus Heating & Cooling
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
Jun 27, 2011 | LG Heating & Cooling
Hello my problem is that my lg ac is not automatically starting when power comes back .please tell me solution how ac can turns on after electricity comes back .thanks
Unfortunately there is no way to make it come on after the power outage without physically pushing the "on" button on the remote or the indoor unit.
It is a big problem with many on the split type A/C units.
Apr 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My LG art cool a/c blades in the vent arent swinging (from left to right)as i keep pressing the swing key on the remote.. please help
In some models, there are swing and sweep motors. Swing will work the vent up and down. Sweep or air flow motor will work for louvers left to right. If sweep motor not works replace the motor. If no sweep motor option, you have to direct by manual only. Be care ful, when you are doing manually, switch of the unit. Thanks.
Feb 01, 2011 | LG LSC121PMA Split System Air Conditioner
Can you tell me where I can get an LG 10501259 remote control for an airconditioning system
Unfortunately, I can't cross your remote's part number - but, this site can find a remote based on your LG air conditioner model number.
If no luck there, your can have a look at this google search result page for LG A/C remote control units.
Lastly, you can contact LG directly or contact one of their parts distributors for the exact part you need, on the LG support page.
One of these methods should solve the missing / broken remote problem for you. Good luck!
Nov 24, 2010 | LG Heating & Cooling
Lmv240he & lav181cnw
I searched the website but could not locate the literature for that particular unit. I recommend you contact the manufacturer's technical support department. They should be able to email you the manual and direct you how to obtain replacement remote controllers.
Technical Support
For technical support on a DFS, PTAC or TTW Product call 888.865.3026, then press 2.
I hope you find this helpful with your endeavor. Good Luck! :-)
Mar 08, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
I do not have the manual for my LG LS-D2461HS air conditioner
On your email you have the model down as LSC121PMA - this is not the model I posted my query on, it ws the LG LS-D2461HS, and no my query is not solved.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Jun 30, 2006 | Zenith DVB412 DVD Player
Heating & Cooling Logo
173 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
