Question about Toshiba 50HPX95 50 in. Plasma HDTV
How to bypass seine card? 50hpx95
How do i bypass the seine card on the Toshiba 50hpx95? I have that continued blinking red light. So assuming its either the Power Supply or the seine card. Please email me at joezambonI@aol.com
Thanks
  • Anonymous Mar 31, 2014
    WHERE TO PURCHASE A SEINE CARD
  • John Elegante Jan 02, 2016
    Question,
    ?Is this the same for other models?
    ?--(I searched for the TOSHIBA 37LX96 Seine Card on the internet and it came up with this answer.)
    Problem Solver:
  • 4 Answers
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Posted on Sep 04, 2009
  • collirg Oct 14, 2010
    I did this and the tv worked.. How do i fix permanent?
I have a Toshiba 50hpx95 plasma tv with a blinking red light. I have already replaced the power supply board and the problem is still there. I need help
I'm no TV expert, but I can share what little knowledge I have, specially what I went through with my plasma TV. It happen in mine, and I got the Y Board fix. When mine was blinking, there was no power, but it wasn't the power board, so searching for an answer in the internet, I found out that it could be one of the boards (Y board or Z board) In my case was the Y board, so I took it to a professional and he fix it for me. IF possible search for: How to troubleshoot TV Y Board.
Mar 02, 2015 | Toshiba 50HPX95 50 in. Plasma HDTV
My toshiba 50hpx95 has a steady blinking red light, it has no pauses or breaks to recite a code, just steady blinking. I had it in the shop and they said the power board needed replaced, so i replaced it...
This tv have a Tuner signal board it is also dead too,this problems happen sometimes,the power supply board dies,but sometimes the Tuner signal board take power surges from the power supply board itself than kiill the tv Tuner signal board too.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.Fixed this problems,many times before.Blinking power LED light.First replaced the power supply board,than didn't solved the problems,than the tv Tuner signal board it is also dies too.
Mar 16, 2011 | Toshiba 50HPX95 50 in. Plasma HDTV
F;lashing power light red, tv wont turn on even after unplugging still wont come
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Toshiba 50HPX95 50 in. Plasma HDTV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
My tv will not turn on and the red led light keeps blinking..what should I do?
You will need to take it to a repair shop. Most likely you have a bad seine board or possibly a power supply issue.
Oct 14, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Power ligh blinking no picture no sound
I had the same problem, it is usually the SEINE module. this unit is about 350 to 400 and they only come refurbished. You can bypass this module which is what I did and it worked sweet, and I have 2 hpx 95s they were both the same problem. This module is for HD off air only so if you are using that then you need a new one if you have cable or satellite save the money and remove the back of the TV and disconnect the module. Give the TV about 3-4 mins to reboot and HELLO TV.
Oct 21, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
Sep 26, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
78c6772.jpg I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
Feb 04, 2006 | Toshiba 42HP95 Television
Toshiba 50HPX95 50 in. Plasma HDTV Logo
1,551 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
