Question about Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher
Water isn't heating up and not drying
Hi I have a Zanussi zsf4123 and it's stopped heating the water up and drying after. Apart from that everything seems to be in full working order. I was wondering if this was a problem with the thermostat or heating element or both.
  • andrealyk Aug 09, 2008
    Zanussi ts853v, water's not heating up and not drying. . Have tried draining the little outlet at the bottom. No solution
  • Anonymous Mar 29, 2014
    Hi the grill in my cooker stopped working so i replaced the element, however the grill now only heats very slowly but does not reach full temp (orange colour)
  • 641 Answers
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Posted on Aug 03, 2007
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
I have Zanussi DX6453 dishwasher. Suddenly it is not drying our dishes. All programs working. Do you think is problem with Element or Thermostat. It is heating water.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
Jul 07, 2011 | Zanussi Dishwashers
My machine has stopped on the display it says e12 whats wrong
Problems with water fill in drying.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
May 28, 2011 | Zanussi Washing Machines
My dishwasher has stopped cleaning plates properly. It makes everything wet but at the end of the cycle the detergent block is half dissolved at the bottom. I have just run a cycle and opened the door...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
kjh;lkhjk
Mar 27, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Dishwasher going through cycle but water not getting hot zanussizsf4143
Heating Matrix faulty. This will need to be taken to a specialist for repair. or purchase new machine - would work out same cost.
Feb 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Hi, my zanussi zdf221 dishwasher wont work, it makes a noise and constantly empties, any ideas please
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Zanussi zsf4123 heating problem
Look at the wiring going to the ends of the heater to see if there is an inline thermal fuse that blows when there is trouble in the heater itself. It is about the size of a regular fuse, but may be contained in some kind of covering. It needs to be connected with crimp type connectors, because soldering can ruin the new fuse. Do you have a wiring diagram for this unit? It would help to locate the source of your problem.
Sep 07, 2009 | Zanussi 18 in. ZSF4123 Slim-Line...
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Logo
545 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
