Question about Car Audio & Video
My baja 50 is bogging and i dont know why
Wont idle. throttle takes a second to kick in. bogs down at the beggining of every gear
    Problem Solver:
  • 14 Answers
Starving for air possibly. try start it with out the airfilter
Posted on Dec 14, 2008
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
I have a 1986 honda prelude2,0si pgm-fi programed fuel injection 12valve.my car in allgears starts bogging out,towards the end of gears.
1985 Vf750F - Bogs Down On Throttle - Maintenance Questions - VFR ...
www.vfrdiscussion.com > ... > Maintenance Questions
Jan 22, 2014 - 10 posts - ‎4 authors
Page 1 of 2 - 1985 Vf750F - Bogs Down On Throttle - posted in Maintenance Questions: Greetings VF braintrust! I have a 1985 VF750F which I ...
Honda Spree and Elite 50 Forums • View topic - 1986 honda spree ...
www.hondaspree.net/phpBB3/viewtopic.php?f=3&t=18521
Apr 9, 2011 - 12 posts - ‎4 authors
Hi all I am new to thie forum. I recently bought a used rebuild Honda Spree. The guy I bought it from ran super unleaded in it and mixes klotz ...
250 bogging down under full throttle. - Honda Rebel Forum
Dec 02, 2015 | Power Flow 1986 - 2001 Honda Prelude Mud...
Wont rev 3000 rpm
You can continue replacing parts at random or have a competent diagnosis made to identify probable causes of the problem(s).
Mar 24, 2014 | 1997 Nissan Pickup
I got a Jeep Wrnagler 1989 5 speed 2.5 liters when it starts it idles high and idles real low
Seems like you got a fuel pressure issue.Bogs down in 3rd. .Then idle high and low.Also check the MAP sensor its up along the firewall.Make sure the hose and electrical is connected,
Feb 27, 2012 | 1994 Jeep Wrangler
When i start my jeep in the cold mornings it starts up but bogs right down and stalls then i have to accelerate for the second start up for a few minutes to warm it up a little and then it bogs and stays...
Your only problem friend, is the temperature sending unit/sensor. Upon cold start, this sensor wil tell the computer to go into cold start mode putting a bit more fuel in and raising the idle a bit to keep it running when cold without using the throttle. Replace that sensor and your good to go. Makes sense, right?
Dec 07, 2017 | 2000 Jeep Grand Cherokee
When i put it into gear the car dies
Sounds like the kick down cable is not working properly. The kick down cable is the cable that tells the transmission to down shift depending on the throttle position. If the cable fails then when the car is turned off and restarted it is in too high of a gear to go and bogs the engine till it dies. Check this out and see if this doesn't get you back in business. Hope this helps. Good luck. cj2176.
Jul 15, 2009 | 1995 Jeep Grand Cherokee
My yamaha pw 50 just bogs down and wont take off starts fine and idles good but when my daughter goes to take off it bearly takes off
clean the carbs, if it bogs you hve to rich main jet if it shuddders you have too lean/dirty jets
Jul 08, 2009 | Yamaha G5 Motorcycles
At Idle Runs Fine, 50% throttle runs like ****
It could be a lot of things, if you can run some component testing. You should be able to narrow it down. Test the TP, EGR, IAC sensor, Look, does the car act up at high throttle while in neutral or just when its in gear? You may want to check the timing and look inside the distributor for any signs of water, rust, or carbon build-up.
Jun 18, 2009 | 1990 Chevrolet Lumina
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
