Question about Panasonic PT-43LC14 43" Rear Projection HDTV
I cant plug in my ps2 to my tv!!
Ok so i read all the other tips on this site and it STILL wont work! I have the red, white, and yellow cords plugged into input 3 and then i set my panasonic tv to the right channel and everything but nothing happens. No sound....NOTHING! Everything has power and i even plugged in something different to input 3 and it worked fine. PLEASE, PLEASE, PLEASE help me.....
  • Anonymous Mar 01, 2009
    I don't know how to plug in the ps2,i need my brother but he will not help me!
Soi didnt exactly fix this but basically i figured out that the ps2 is simply too old for that new tv. when i plugged in a newer system it worked just fine so i guess ill just have to deal.
Posted on Dec 15, 2008
How to hook up the wii cords
First, you are posting a question about the Wii under the PS2 heading. Problem number one! Number 2! If your TV is new enough, it might not have the connections for A/V jacks like the yellow red and white. Here is how they connect. Yellow, video, Red, right sound, white, left sound(mono)
Jun 11, 2014 | Sony PlayStation 2 (PS2) Console
How can I hook up my ps2 to my Philips Magnavox TV?
First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX)
Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working!
If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322)
Hope that helps.
Jul 16, 2013 | Philips Televison & Video
I need a printable version of how to hook everything up. Please. We have a PlayStaion2
  1. Place your ps2 in an area that will allow for plenty of airflow, and is relatively close to the television that you intend on hooking it up to.
  2. Step 2 Check your TV or monitor for available video inputs. The most common are composite cords, which come with a new PS2. This cord has one plug on one side, with the other side having three ends colored yellow, white and red.
  3. Step 3 Plug the single end of the video cord into the back of the PS2. Plug the other side of the cord into the corresponding colors in your video input on your television.
  4. Step 4 Plug the AC adapter (power cord), into the back of the PS2. The other side of the cord should then be plugged into the wall. A red right will appear on the front of the PS2, signaling that it is on standby mode, and receiving the required power.
Jan 05, 2010 | Sony PlayStation Portable (PSP) Console
I have 2 ps2 how do i link them to to tvs
SONY Instutions that came with it.....
SIMPLE: CONNECT THE FOLLOWING TO THE TV FROM THE PS2 VIDEO CORD.
YELLOW TO YELLOW
RED TO RED
WHITE TO WHITE.
Coax is much simplier.. Screw the Coax cord to the back of the PS2 to the TV.
Jun 29, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 will not display nor play sound
try checking the three coloured plugs in each end of ps2 and tv you noe the red yellow and white plugs make sure they are in the rite order
Apr 24, 2009 | Sony PlayStation 2 (PS2) Console
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Dec 30, 2008 | Durabrand DWT1304 13" TV
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Mar 21, 2008 | Emerson EWF2004 20" TV
My ps2 wont work on the TV
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
Feb 10, 2008 | Sanyo DS31590 31" TV
PS2
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Jan 06, 2008 | Televison & Video
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
