Question about Car Audio & Video
Why is my amp cutting out
It works for a min then dont
    Problem Solver:
  • 14 Answers
This has happened to me a few times. unhook everything and check your wiring. jst have your ground remote and 12v wires on. see if it turns off. sometimes it depends on your speakers. bit vague.
Posted on Dec 14, 2008
Why does sound cut in and out?
Sounds like the power amp is going bad..it might be a board for that repair...dont know alot about that model...
May 28, 2014 | RCA L46WD22 Television
Mercedes vito engine
I would think the crank or cam sensor is failing. (over heating) dont know the age of yours. it could also be the emissions sensor some were fitted that cut the engine out if it fails.
Dec 08, 2013 | Cars & Trucks
1993 chevy cavalier 2.2 engine cuts off when cold or hot
Someone will need to check it over when it fails to start. You need to know if it is not getting fuel to the injectors or spark to the plugs.
Jul 28, 2013 | Cars & Trucks
Start pro blem
neut lock switchposible
Jul 14, 2013 | 2003 Chevrolet TrailBlazer
I need a fuse box diagram for a 1997 Plymouth Voyager
my 1997 plymouth voyager cuts off after 20 mins or when coming to a complete stop.. If i put water on the core by the engine, I can crank it back up. but it still cut off after a few mins.. the gaggs dont go over half... i dont know what it is... unless its the computer box..
Jul 25, 2010 | 1997 Plymouth Voyager
My amp is working but everytime it cuts off and i got to cut off my car and cut it back on. Also when i have the car off and i have my radio on it stays on. But when i am driving like 1 or 2 mins it cuts...
Check your ground wire and make sure it is bolted down into a solid ground. Do not use a factory ground make your own. Every system that has subwoofers has a little blue wire called a remote wire. The deck sends a signal to the amp thru this wire letting it know it has been powered on. It could be that there is a short in this wire, either from the deck side (where the wires are connected) or it could be also be detiorated insulation on the wire. pretty inexpensive to replace. In my opinion it sounds like you have a shotty ground wire. If you don't have this grab yourself a nice foot of 4 guage wire at your local HI-Fi shop. This should fix your issue if not let me know and we will keep troubleshooting
May 20, 2010 | Lanzar MXA232 Car Audio Amplifier
I cant cut very well and i dont learn how cut in position correct
keep the cutting tip just off the surface and try to hold gun straight up and down,if it dont cut through work peice turn the amps up.
Jun 04, 2009 | Airforce Welding Tools
500/1 and 300/4 jl
Need more info here. did you run power from the 500/1 to the 300/4, or did you run the signal from the 500/1 to the 300/4? Also which amplifier is cutting out for a min...the 500/1, the 300/4, or both? each amp should be wired to a distribution block with 4 awg power wire recommended for each. the amps should also be wired without any capacitor.
Mar 17, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
