Mine also says "remove and check color cartridge" even after replacing it. Oddly enough, it will still print, but won't copy or scan. Mine also says "remove and check color cartridge" even after replacing it. Oddly enough, it will still print, but won't copy or scan.
Color prints are streaked in regular 3/16 inch bands. replaced color cartridge and still the same streaks?Color prints are streaked in regular 3/16 inch bands. replaced color cartridge and still the same streaks?
AnonymousDec 23, 2008
"Remove and Check Color Cartridge" won't go away w/ new cartridge problem, and notify you when a new solution is offered.
I have same problem, but I can print both color and black and white. I can fax and copy. Both print cartridges are new HP cartridges, not refills.I have same problem, but I can print both color and black and white. I can fax and copy. Both print cartridges are new HP cartridges, not refills.
AnonymousApr 04, 2009
same problem, haven' t got a solution.
You can't post conmments that contain an email address.
Hi
There are two main reasons for this problem, one is that the colour cartridge has insufficient ink in it, even if not showing as such, and the other is that the cartridge is a compatible, and not being recognised, this can be the case even though the cartridge was accepted originally. Its worth noting that many printers will not print unless all cartridges are in full working order, even if the non-working cartridge is not required for the print job that is wanted.
I found a full manual here: http://h10032.www1.hp.com/ctg/Manual/c00369567.pdf
which has some useful information about troubleshooting such issues.
Hope this is helpful, if so would you please register that with Fixya
Cheers
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Try this procedure: 1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and
place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
When one or more ink cartridges are empty, for example, Black, the LCD
shows “Ink Empty Black” and “Open Cover.” Close the printer’s document
support and the document tray.
Lift the top cover to the open position until it locks securely into place.
Pull the ink cartridge hook toward the front of the printer and remove
the color ink cartridge displayed on the LCD. Place the cartridge in a
plastic bag as it may still contain some residual ink and may leak.
Open the new ink cartridge bag for the color shown on the LCD and
remove the new ink cartridge. The cartridge cover may come off when you
open the bag. This is not uncommon and will not damage the cartridge.
Each color has its own correct position that is clearly labeled and
color coded inside the printer. Keep the ink cartridge in an upright
position when you insert it into slot. It will only fit in the correct
direction. Press down on the ink cartridge until the hook snaps over
it.
If you replaced an ink cartridge while “Near Empty” was displayed on
the LCD, the LCD may ask you to verify that the replacement cartridge
was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For
each new cartridge you installed, press 1 on the dial pad to
automatically reset the ink dot counter for that color. If the ink
cartridge you installed is not a brand-new one, select 2.
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Same problem with two new color cartridges. Printed picture with one and red was obviously missing.
