My pilot tries to light but never ignites. the system basically just circulates cold air.
    Problem Solver:
  • 12 Answers
The most common reason a pilot will not lite is a bad thermocouple. This is the thin copper tube that runs next to the pilot and to the gas valve. These are inexpensive and pretty easy to change if you are mechanicaly inclined.
Posted on Dec 16, 2008
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Jul 26, 2012 | Water Heaters
How do I install a basic vent system to create air flow in my basement?
Your air circulation knob or switch has 2 settings ,recirculate and fresh air,turn to fresh air,put on cold and turn the fan on to your speed you want and air will circulate from the outside to the vents,put it on mid level.
Jul 22, 2012 | Cars & Trucks
The pilot loghts in my forced-air furnace, but
ignition module, pressure switch and its tubings attachment orifices plugged
Dec 03, 2009 | Heating & Cooling
Unit blows cold air. Igniter continues to try to ignite burners but no burners light.
if you are getting that far in the sequence see if you have 24v to the gas valve the gas valve could be bad or if your unit starts a pilot flame you might have a clogged pilot tubing could you post your brand model ande serial number if your problem is not resolved
Jul 06, 2009 | Vulcan Heating & Cooling
My Amana furnace is acting up.  The pilot light works just fine and the system starts up but then shuts off immediately.  It will keep trying to start but then just blows out cold air.  Then after trying...
The furnace is not sensing the flame and is shutting off the gas. What kind of pilot do you have? If you have a Hot Surface Igniter(glow coil) It will try to igniter three times and go into safety default for awhile to clear any gas that may be in the area.
Check to see if you have a small rod that protrudes into the flames. It's usually located on the burner on the opposite end of the pilot but may be closer. Clean it with sand paper. if that works then it bought you time to get a new one. They are inexpensive.
If you have a spark igniter then clean the rod(s) on the igniter. This may work but not as often as the HSI. Good luck.
Jan 17, 2009 | Heating & Cooling
The heater in my central heating is not getting turn on but the fresh air and cooling is getting turn on
Check the pilot light.Older standing pilot systems use thermocouples to verify the pilot is burning before the gas valve opens.If the pilot wont stay lit replace the thermocouple.
Newer systems light the pilot.On a call for heat the igniter lights the pilot. When the heat is verified the gas valve opens . Some systems use an circuit board with flashing led lights to help troubleshooting.
Jan 11, 2009 | Heating & Cooling
EA error msg on Bosh tankless unit
How I fixed it was got rid of it...support help never called back..and to get parts for it was looking into the new year can't go without a shower that long...can we now?
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
