Question about Sony KP-51WS500 51" Rear Projection Television
Further assistance needed
Model is a Sony KP-51WS500 rear projection tv.
The problem is numerous very fine horizontal blue lines veiwable when the background black.
The blue lines aren't perfectly horizontal, they curve a little bit.
The fine blue lines are only visible when the screen has an area of black on it, not visible when the screen is showing any other color.
Thank you in advance
welcomejee
Rank: Guru
Rating: 87%, 1221 votes
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Comment posted on Dec 13, 2008
Thank You,
I do have some experience in electronics, build circuit boards as a hobby.
Is G2 a variable pot that can be adjusted?
And what is the voltage for that pot (or do you just decrease until the blue lines dissappear?)
if so ...with some assistance as to the location of the pot for the blue gun (G2) i'm sure I could adjust it and check the voltage with a multimeter.
  • 10,594 Answers
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Posted on Dec 13, 2008
I have a Sony rear projection tv model KP-51WS500. It has had some fine green lines across the screen, but today it has started to fade to green after being on for a few seconds, then truns off. Any...
It sounds like the focus pack needs to be replaced (p/n 122392535) and re-adjusted. The re-adjusting could be the tricky part if you haven't done these before.
Jan 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Blue screen
u have bad blue picture tube , $300 - $500
Apr 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Have sony kp51ws500 won't turn on, it clicks then shuts down and i get 7 blinks on front--had green, blue, and red line issues before
Hi wright
To answer your question;
The 7 blinks code(sony error codes) means that the horizontal deflection has stopped.
The common cause for this are transistors Q8035,Q8038 and the horizontal output Q8024 all located on "D" board.
Hope this help and let me know if you need further assistance.
Feb 18, 2010 | Sony KP-51WS500 51" Rear Projection...
Kp-51ws500 all my channels have a blue hue to them Color adjustments on menu do not help TV is 5 years old, just started recently
if blue has retrace lines,turn down blue g2 control located through the front of tv after front lower bezel and cover boare removed
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Very fine blue lines veiwable when the background has black in it
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Have a sony kp-51ws500 need Blue Picture Tube
Try this link leave them an email with your model number and which tube you need they should be able to locate one for you.
http://servicemanuals.vstore.ca/
Apr 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
145 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
