Question about HP DeskJet 5652 InkJet Printer
No power ON
When applying power to the printer, the Green ON button lights briefly, then goes OFF and the Cartridge Yellow button comes ON and stays ON. There is no movement in the printer, i.e. it does not even do a self test!! Any idea what may be the cause? Another problem I noticed ... I could not remove the ink cartridges - the 'black plastic' moulding (don't know its use) in front of the cartridges was in the UP position and blocking the extraction of the cartridges.
  • Jackkron May 07, 2008
    Have same exact problem, lid closes good and presses the switch.
    Scholar:
  • 121 Answers
Here is what HP suggests: Issue The top access door on the printer may be open, or there may be something wrong with the print cartridge. Solution 1. Check to ensure that the top access door is firmly closed. 2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom. Here is a link to describe the pictures at the top of your printer: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=e&product=304442&rule=36405&docname=bpd09173 It might be that the cover's tab is broken (the tab is what tells the printer that the cover is closed)
Posted on Mar 27, 2007
SOURCE:
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Canon ip2770 error 5100 and 5200
    How to Reset Canon IP2770 Error 5100:
    Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
    To solve these follow the following steps.
    Turn off printer
    Remove both the cartridges from the printer
    Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
    Return the cartridges
    Turn on the printer.
    Error will be removed
    How to Reset Canon IP2770 Error 5200:
    1. The printer is turned off and plugged the power cord.
    2. Press Resume button 2 seconds
    then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
    3. Then release the RESUME button, but do not release the POWER button.
    4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
    5. Release both buttons simultaneously.
    6. Led will blink briefly and then will glow GREEN.
    7. And the computer will detect new hardware, just ignore ...
    8. Press the POWER button, then the printer will die.
    9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use.
    Other Ways Reset Canon iP2770 error 5200:
    1. Turn the printer, and printer will look normal.
    2. Run the printer for printing documents or print test, then the 5200 error will appear.
    3. Jump unplug the power cord without pressing the on-off
    4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
    5. Unplug all cartridges and leave the lid remains open
    6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
    7. Replace the cartridge, and close the correct
    8. Your printer will return to normal. (Source: from all existing sources)
    I hope this solution will helpful for you
    Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
    THANKS & Keep Using fixya
    Jul 27, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
    Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
    Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
    May 17, 2011 | Canon iP100 Portable Printer
    How to remove the ink cartridges?
    r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
    Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Watch the control panel.
    When the memory starts counting, press and hold the green (Select) button.
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Release the check button when the Ready, Data, and Attention light are on steady.
    The control panel will display SELECT LANGUAGE.
    Press (Down Arrow) button once. The control panel will display COLD RESET.
    Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    Hp 2200d laserjet
    possiably bad gear assembly.
    Sep 21, 2008 | HP LaserJet 2200D Printer
    New HL-5240 printer red status light upon powering up
    My HL-5240 did the same thing, Here is what I found:
    Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
    Jul 22, 2008 | Brother HL-5240 Laser Printer
    Epson stylus 1280 printer
    Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
    -You cannot print if any ink cartridge is expended.
    -Leave the empty cartridge installed in the printer until you have obtained a replacement.
    Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
    1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
    2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
    3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
    4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
    5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
    6. Press down firmly on the ink cartridge clamp until it snaps in place.
    7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
    8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
    9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
    Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
    Power & Yellow Resume Button flashing constantly & will not print
    Ok please try
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
    Not working
    This maybe down to a faulty cartridge replace cartridges and then retry. You can try the following to obtain a test sheet.
    • Turn on printer
    • Hold power button down (While printer is on)
    • Press the paper feed button once
    • Release both buttons
    This will printout a test sheet but I really do think that it is a faulty cartridge problem.
    Hope I could help
    Thanks J
    Dec 08, 2007 | HP DeskJet 1220c InkJet Printer
    HP DeskJet 5652 InkJet Printer Logo
    73 people viewed this question
    Clive
    Clive
    Thomas F. Schneider
