Question about Thomson 28VK25US TV
TV Stuck - Probably Thompson as says Black Diva
On turning on the TV it shows a blue language menu, i dont have the remote and the buttons on the TV wont change it.
I have a universal remote but it does notseem to get a code or operate it in order to select english as such, The uni remote did turn the tv of at one point as it auto searched etc
Any advise please
thanks
  • kat5k Feb 01, 2009
    I have exactly the same problem. TV just shows blue language screen. Unplugging didn't help - even after an hour off, screen still comes back. I have no remote and can't find a way to get rid of this screen. Did you find a solution?
  • Anonymous Mar 22, 2009
    Exactly the same problem. Have a new universal remote but cannot click ok to make screen go away,
Sevice mode remote code
Posted on Dec 31, 2008
Changing the language to english on my blu diva t272t
1. Open Menu
2. Go to the "Ajustes" (it's Settings on spanish)
3. Click and open Ajustes (Settings)
4.Scroll to the "Lengua" (it's spanish word fro language)
5. Press and choose English
Hope I was helpful.
Feb 02, 2014 | Blu Diva X Mobile Phone
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
Apr 10, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Tv stuck on menu
Greetings!
These Orions and the Emerson units built by Orion all revert back to set up after being unplugged for a given length of time. The situation can be rectified on the front panel without the use of remote. Please forgive if this seems over-simplified:
1. Turn on the set.
2. When screen appears push "FF" or "REW" button to select the desired language.
3. Push "PLAY" to move the arrow down to "Auto Preset".
4. "FF" to engage the auto channel programming.
5. When the set is done auto-programming the menu will clear and you use the set normally.
Rob
Jan 14, 2009 | Televison & Video
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Televison & Video Logo
929 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
