Question about Jensen VM9510 Car DVD Player
Bypass e brake switch 4 jensen vm9021ts multimedia system.
Was able 2 watch any time.but hit the reset button,now cant watch.any body with solution.
4 Suggested Answers
SOURCE: bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
Posted on Dec 14, 2007
SOURCE: JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Posted on Mar 20, 2008
SOURCE: how do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Posted on Nov 16, 2008
SOURCE: bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
=ps2 needs to be reset every time you switch movies or games
All ps2's need to be reset when switching movies or games. You shouldn't have to hit the power switch just the power button on the front.
Mar 23, 2011 | Audiovox VOD10PS2 Car Video Player
No picture on tview dvd70ts
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Apr 08, 2009 | T-View INDSH DVD PLYR W/TUNR Car Video...
Lost id security code ,cant use radio
you have to hold the joystick to the right for 10 sec then hit the mode button and that should reset the unit to defult then the code will b 0000
Apr 06, 2009 | Panasonic CQ-VD7001U Car DVD Player
My Avic d3 won't eject
Try holding the menu and left arrow button at the same time you hit the (little) reset button. As the system reboots hit the eject button a few times. You may need to do this cycle more than once.
Nov 15, 2008 | Pioneer AVIC-D3 Car DVD Player
Want dvd to play while driving its played before i hit reset button now it does'nt play
You need to hook up the pink wire to a power wire. I myself have a switch in my cig outlet (which ran blue lights i had inside my car) running it so if i ever got pulled over i just pull out the switch and they cant prove i was playing a movie.
Oct 19, 2008 | Phase Linear UDV9010 Car DVD Player
Set the clock
The D3 is set automatically to West Coast (PST) Time. Only when you reset the D3 can you change the time. Hit the reset button and you'll start setting up the settings. It will bring you to the clock feature. Depending on where you are in the country you will need to hit the [+] button one click for each time zone east (i.e. East Coast (EST) is three clicks). Then you need to hit the "Summer Time" button becasue of Daylight Savings Time.
As for the Phone Book I don't use that feature so can't help you there
May 16, 2008 | Pioneer AVIC-D3 Car DVD Player
Dual xdvd710
Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
Mar 24, 2008 | Dual Electronics XDVD710 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Phase linear uv8
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Dec 03, 2007 | Jensen VM9510 Car DVD Player
Pin hole suggestion used but still asking for a code? (CQ-VD6503U)
i just fixed mine had the same problem just hold the the right track button firmly until it resets it self and it worked for me hope it does for u
Oct 15, 2007 | Panasonic CQ-VD6503U Car DVD Player
Jensen VM9510 Car DVD Player Logo
330 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
