My monitor will not work.
I have replaced the video card in my pc and now I can't get any monitor to work on it. it is a gateway pentium xp mfauxrul elp 500s
    Problem Solver:
  • 4 Answers
Hi!
just passing by and i saw your concern.
this may help,
it could be *********** board bios and the buillt in VGA is on.
try placing your monitor on the built in display port at the back of your pc most of the time youll find it on near the usb and port.
and if display came up on that port meaning you have to disable built it display inside the bios setup.
you can stay to that display port to get the bios diplay setup change.
Providing me the model and make of your PC and your monitor will help a lot.
hope this gives you some idea whats happening to your pc.
Posted on Dec 13, 2008
    Novelist:
  • 115 Answers
First of all, and I know this sounds ridiculous but I've even done it, make sure you connected the monitor cable to the new video card and not to the old 'on-board' video connection.
Next, do you get a (BIOS) start-up screen? If you don't, you most likely have a bad or incompatible video card. If you do, you need to boot into the 'BIOS' setup by holding down which ever 'F' key your particular computer calls for, (I don't know the make of your computer), and look for video or display options and choose the appropriate setting (PCI or PCI-Express), 'Onboard' is the factory default and will only work with the monitor cable plugged in the 'original' connector.
If you still can't get it to work you may have to put the connector back on the original, then go into 'Device Manager' (right click My Computer - then choose 'Properties', then 'Hardware' tab, then Device Manager), go down and open 'Display adapters', choose update driver on the new card's entry and then 'disable' the original device. turn off PC, reconnect the monitor to the new card and reboot. Good Luck!
Replacing video card
Video card is ok if you can see second monitor, is this a laptop, if it is there is a good chance monitor or what is called inverter is bad...
Sep 30, 2013 | MSI Wind Top AE2020-098US Desktop Computer...
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
When i connect my desktop to my monitor i don't get any visual picture, but when i connect my laptop to my monitor i do. My desktop is gateway gt5465e
So it sounds like your video card on your desktop. The best solution here if you are not looking to spend much money is to buy an off board video card. It looks like from the specs on this model you should have a spot for a pcie x16 card.
This link is a cheap one from newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16814500118
Feb 13, 2011 | Gateway GT5465E Refurbished Intel Desktop...
The computer has lost all the red color and others
Hook up another known good monitor to the video card and if it still has problems with red then you know the video card is bad and needs to be replaced.
If the known good monitor still works after being hooked up to the video card then you know the original monitor is bad.
Let me know if I can be of further help.
Ben
May 14, 2009 | Gateway GT5220 PC Desktop
Gateway E-4200, Pentium III, Win XP, Nothing Showing On Monitor
The beeps are usually an error code meaning either the RAM or video card has went bad or are not properly seated. Leaving it out as you did could have caused the parts to come unseated when you moved the unit. Try reseating the RAM & video card and then retry booting. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Gateway E-4200 Notebook
Newer monitor to older xp pc
If your monitors are displaying "no signal" they aren't receiving input from the video card. If your PC has two video outputs (onboard) try charging to the other output to see if it will come on. Also reseat your video card in its slot. Also, what can you see that lets you know the keyboard and mouse are not working?
Dec 29, 2008 | Computers & Internet
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Vertical lines on monitor
your video card may be failing. do you have a add on graphics card. If you do try your onboard card. Have you changed the Hertz setting in your display settings and also try the DPI options and change it to a higher setting. See if that works
Dec 24, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
