Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't install HP2545 printer
Have loaded and uninstalled software twice that came with printer. Error message says 'cabinet file corrupt'. It stops each time at 94%. Says I can still use printer without some of the options, but it won't print anything, Help!!!
    Master:
  • 461 Answers
Could be a faulty disc. Download the drivers from the HP Website.
Posted on Dec 14, 2008
0x95 error
Epson Printer Error 0x95 occurs when the printer head is saturated,i.e; cleaned. Error may be due to installation or uninstallation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Check Epson Printer Ink head. Generally, Printer ink is dirty meanwhile it is inked up properly because the ink pad is full. Often due to unbalance ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Try to switch on your Epson printer.
  • Then "press+hold" together to stop ink power buttons.
  • Wait for sometimes while the printer switches self OFF.
  • Next switch back ON and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about whether your error existence effectively solved.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Apr 01, 2014 | Epson B510DN InkJet Printer
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
I tried installing my new Serif x4 software and it did not complete the installation due to the following error message: installation error: 'wp.cab' / 2350 code
It's missing a major cabinet file.
Are you using a genuine disk or download?
If a download, redownload it, the file is corrupted.
If on disk, use original disk NOT a copy as it won't work.
Dec 30, 2010 | Serif WebPlus X4 for PC
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Error: 0x80040702 Failed to load DLL :
It sounds like the uninstall files have been corrupted. The best option in
this case is to reinstall the game and then uninstall it.
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Scanning stops unexpectedly. Message reads "The wizard did not successfully complete copying your pictures because the process was cancelled." It was not cancelled. Nothing was touching the mouse or...
This is a software issue. Somehow the applicaiton drivers are failing to complete the routing. This indicates corrupt printer application files.
You will need to uninstall the printer software, restart the computer then re-install the software.
Oct 03, 2009 | Canon PIXMA MP190 All-In-One InkJet...
MS Office 2007 Professional won't install on my Laptop with XP
yor ms office 2007 cd or dump is corrupt pls try another one
Jun 24, 2009 | Microsoft Office Publisher 2007 for PC
Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
Apr 07, 2009 | Dell Computers & Internet
I cannot install my Hp F4135 all-in-one printer. The message is : Cannot install this hardware There was a problem installing this hardware HP Deskjet F4100 series An error occurred during the...
Did you plug in the printer to your computer before you installed the drivers?
If yes unplug the printer, un-install the printer drivers, restart your computer, install the drivers, then plug in your printer when prompted.
Are you running Vista as your operating system?
If yes you may have to go to the internet to find the Vista drivers.
Dec 06, 2008 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
83 people viewed this question
Ben Johnson
