Question about Panasonic CT-35SF23 35" TV
Subwoofer buzzing I have a Sony STR D560Z and when I bought this 12 years ago, I didn't have a subwoofer to plug in. Everything worked fine. Two years later, I upgraded my surround sound and added the rear, center channels, and of course a Cerwin Vega 12 inch powered subwoofer. From the beginning, the sub would buzz using the cord provided from CV. So instead of using the cord, I just ran the right and left speakers through the sub and ran the right and left front speakers from the sub and everything was hunky dory. When the CV Sub fried its card, I bought a lower priced 8 inch subwoofer from JVC. It has no other means of plugging it in except the cord provided. I plug it in and it buzzes too. I can fold the cord over itself and the buzzing stops and the sub works normally, but as soon as I release it, it starts buzzing again. The CV sub did this too so I know it is not subwoofer. I can plug the cord into any other audio out and it works without problem. Is there a cord provided by Sony that will prevent this or is the problem the receiver?
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Feb 15, 2015 | Sony STR-DE597 Receiver
Hi, having a problem with my Sony STR - DB790 amplifier. All my surround sound speakers work fine, but my subwoofer is not. The subwoofer has power and is connected using the co axial cable. The...
RCA cable. It's called RCA when carrying Line Level audio; Coaxial when carrying digital data.
Does the sub work when you run speaker setup? It's in the manual.
Apr 01, 2011 | Sony STR-DB790 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Buzzing sound from woofer when I plug in
If the woofer works fine when plugged into any other port, I would say that you have a connector on the receiver that has a loose connection or possibly a cold solder joint (poor or broken solder joint). RCA jacks can be stressed quite a lot especially if you use cables that have very tight connectors. The female RCA jack gets wiggled or twisted when trying to remove a cable and this causes solder joints to crack. I would have a look at that connector on the receiver..
Mar 02, 2017 | Panasonic CT-35SF23 35" TV
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
