Question about Magic Chef CMV1000B Microwave Oven
Only 1 function works at a time on mco16
If the timer is set can't do anything else. Can't cook and set timer. Has no interior light. Is this just a lemon?
  • Magic Chef Master
  • 9,098 Answers
That actually sounds like correct operation in that you cannot use the timer while it's cooking.
Assuming yours is model number is MCO160S, you can download your owner's manual here if you don't have it.
Page 19 tells you how to replace the cooktop lights and the cavity light.
Posted on Dec 15, 2008
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
Either your microwave is defective or you don't understand how to use it. Try Googling (Kenmore)(74229)(manual) without parens to get instructions or go to www.searspartsdirect.com for the same.
Sep 16, 2016 | Kenmore 74229 Elite Black Countertop...
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
I have an emerson 900w microwave mw8999sb sn908003050mm. I have tried cooking in it and setting the timer at the same time to time something else that I am cooking. Can it be done with this type of...
The owner's manual is here, and it does not mention that as a feature.
One way to prove that is to press the "Kitchen Timer" pad while the oven is cooking and see if anything happens.
No modern microwave that we know of has this dual function, but it sounds interesting.
Nov 28, 2009 | Emerson MW8168B Microwave Oven
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Interior light won't go off
Asta, the cavity light runs through the secondary door switch which is the top one. Sometimes during shipping these switches get knocked loose from there mounting and the oven starts doing some funky things. You can remove the control panel and get a look at these switches, they will be to the left. See if they are all secure in their mounts. Also check the p-4 harness on the board, re-set it. This is where the cavity light relay harness is. If it's new, call for warranty service...high voltage here, be careful....Catriver...post back.
Sep 13, 2006 | Whirlpool MH1141XM Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
75 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
