Question about Sharp R-1870 Convection/Microwave Oven
I have R-9X58 timer that stopa @ 5min when in convection mode
I have R-9X58 microwave that stops @ 5min when in convection mode. It stops heating from the 1.5kw element before it gets hot enough, if you reset it stops at the same point again. Between my son, sister rentals and self we have 4 Sharps doing the exact same thing The timer seems to be the same type used in all of them. I would like to have a go at the repair as I have had 6 Sharp microwaves myself that all had done the same thing. Also the display is quiet dim but this is minor as we need convection oven first. Sharp needs to be made aware of issue as service cost varies greatly. Please help sincerely, Terry Dowsett canabus@mpx.com.au
  • backgate Dec 14, 2008
    No solution yet If you can assist I would be very greatfull
  • Sharp Master
  • 9,086 Answers
"Convection cycle runs 4 minutes and 15 seconds then shuts down."
In most cases, this is a bad thermistor, but it may also be loose wiring, or a problem on the control panel.
The thermistor should be on the top of the chassis and it will look like one of the attached drawings.
You will have to remove the outer cover of the oven to get to it.
THERMISTOR TEST
Room Temperature 68°F(20°C) - 86°F(30°C)
Resistance Approx. 350k ohms - 155k ohms
(The higher the room temperature, the lower the resistance, and vice-versa).
If the meter does not indicate above resistance, replace the thermistor.
Also, if the thermistor is caked with grease, or it's rusty, it will need to be replaced.
If it has a broken lead, it cannot be repaired unless you spot weld or braze it, and if you get it too hot, it will be destroyed.
To find the thermistors, you can visit Sharp's Australian support site and click on the "Spareparts Outlets" link under "Frequented Resources".
(If you're not in Australia, please write back and let me know where you are!)
Posted on Dec 15, 2008
  • mr slacko Dec 29, 2010
    2010 and mine has joined the lost of failing,
    have orded parts and replaced and problem solved
    cheers and many thanks
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
I need a manual for Sharp Convection Oven Model R-9X58
I cannot find a free one, but since this was given to you, this small price might be worth it.
http://www.bonanza.com/listings/Sharp-R9X58-Service-Manual-Mauritron-2081/45526894
Sep 16, 2014 | Microwave Ovens
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
May 11, 2013 | Sub-Zero MW24 Microwave Oven
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
I have owned as many as 6 Sharp convection Microwaves, they have all suffered the same fate. The timer when in convection stops at approx 5min in this time it has not heated hot enough and each time is...
THERMISTOR TEST
If it has a broken lead, it cannot be repaired unless you spot weld orbraze it, and if you get it too hot, it will be destroyed.
To find the thermistors, you can visit Sharp'sAustralian support siteand click on the "Spareparts Outlets" link under "Frequented Resources".
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Dec 13, 2008 | Microwave Ovens
Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
338 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
