Question about ECM Giotto Espresso Machine
Pressure gauge ECM Giotto Premium not functioning
Hi, I have a problem with the pressure gauge lately. tried descaling which I had to do anyway but that did not solve this problem.
Any idea doesn't get used a lot last time 2 months ago.
  • olev Mar 21, 2009
    First of all, this is no rocket science. The entire machine is built from industrial fittingns and European 6/4 mm or 10/8 mm cupper pipes. Open the machine and - eureka. 2 or 3 fixed keys will open the pandoras box! PLS !! take a few Digital photos PRIOR to open the machine. Otherwise you end up with a box of pipe details - with no home. A lot od the parts can fit two ways! Check valves get filled with scale and need manual cleaning after some years. Forget about chemical cleaning as it does not reach the boiler itself. Filling the tank with anti scale distoys the element. The pipes themselves get bocked with time/// Olev
  • boonzajer May 11, 2010
    Are you relating to the pressostat, to the probing stick or to the pressure meter on front?
SOURCE: ECM Giotto Premium (S/N 20030100413, purchased May 2003)
Often the problem is the reservoir sensors think the water tank is empty. The metal rods that go into the white plastic tank are the sensors, and they contact the sides of the machine to provide an electrical ground. The water needs to be normal tap water, distilled water will not conduct...
At any rate, the fix is to simply jiggle the tank left to right to roughen up or clean the contact between the sensors and the body of the machine. Within a few minutes the machine should start to heat up, now that it knows you have water.
Hope that helps!
Posted on Jul 15, 2008
  • 9 Answers
SOURCE: No Pressure..No heat
Se my solution re no heat on page. pressostate or microswitch fail is easy to fix. many times the water tank is bebt out of shape with time. A twisted tank lift one side and tank is no longer resting on four points. This cause no contact with electrodes inside tank saying = no water = no power allowed. The GROUND must be established! A small piece of alu foil rolled to a ball will help to ground the electrode again. Lift the tank gently and find the two v - shaped contacts for the electrodes. Have also replaced the electronic box once :-( on friends ECM /// olev
Posted on Mar 21, 2009
  • 9 Answers
SOURCE: ecm giotto repair
Jonny boy,,If you ever had a Macano box as a kid, tthe best man to fix the machine is you! Take many photos before opening the pipework. Clean out the scale and learn about your machine! No kidding, you brew a better coffee after that. You know ALL the functions after looking into the machine + ther are some ways to tweek it too. Steam press cam be set as well as water amount. I brwe a better espesso tha I get on town. Thick light brown crema. I gave upo with the dealer and hes so called repair people /// Olev
EsWorld
  • 1618 Answers
SOURCE: ECM Giotto group gasket and shower plate falling out
I am assuming that you have basket style shower which sits in the gasket and then inserts in the group.
Find the small bevel edge on the gasket, make sure that side is facing up, place gasket on table then insert shower in gasket, then lift gasket, until it sits at the top of the shower(use a small flat screwdriver or a small hard brush to clean the group where the gaskets seats), then insert gasket and shower in group. Push in as far as you can then use the portafilter to seat the gasket in all the way.
If your shower is the flat style then there should be a hole in the middle for a screw.
Posted on May 30, 2009
espressonist
  • 1711 Answers
SOURCE: Hey!
The pressostat can be full of scale. You can remove it when the machine is cold descale it and also use a litle lubricate so the part can move more easily. You migh need a new mebrane since it might have be damage but if you dong have you can cut a plastic the same round shape of the mebrane and put the both back again so that no steam will escape from the mabrane.
Posted on Feb 16, 2010
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
Giotto Premium problem...
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
May 29, 2008 | ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
Hey! My ECM Giotto is building up too much pressure. 2+ bars. I tried resetting it but no lick. New thermostat?
Feb 13, 2010 | ECM Giotto Espresso Machine
Boiler bar gauge has no pressure
please check to see if its not sticking refill with water
May 04, 2009 | ECM Giotto Espresso Machine
Machine is on but no pressure and no attempt to make any
Open the top panel of the machine there is a small reset thermostat, that may have have tripped, push in to reset(sometimes reset is on the element).
Mar 31, 2009 | ECM Giotto Espresso Machine
Nov 19, 2008 | ECM Giotto Espresso Machine
Giotto pressure valve constantly on
You must have an internal leak and your machine will need to be serviced. If you can remove the top of the machine maybe you can see where the leak is coming from and may be able to repair the machine yourself.
Cerini Coffee
Espresso machine service and Sales
www.CeriniCoffee.com
Nov 10, 2008 | ECM Giotto Espresso Machine
Giotto premium - is it a lemon?
My friend, had the same feeling,,,What have a done !! This piece of junk for all my dollars! No ,,it needs cleaning. Read all my comments re this. You can open this machine witha few fixed keys and mantain it. It will outlast you, when correctly mantained. All solid cupper and metal, no plastic. take it apart and CLEAN IT!
Remember - it is built by a human beeing. The ECM is a buty as it has very little automation built in. Very siple function = löong time in love with your machine. It is totally ANALOG = tweek it = better cogffee. /// Olev
Aug 23, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
263 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
