Question about Kenneth Cole KC4232 Wrist Watch
Backing will not come off
My watch is running slow, which jewelers are telling me is a problem with the gears (either need to be cleaned or replaced) however I can't get the backing off of my watch. I have had three watch repair/jewelers try to get the backing off, and the lip is flush to the back of the watch, so there is no space for them to get their tool. Any ideas?
  • Anonymous Jan 26, 2009
    me too
Please call 1-7187298600 X272 ask Linda, the geneva watch group watch service ,we will take care of this problem, but send the watch along with a brief note on the watch problem to Attn: Tsai
Posted on Dec 08, 2007
I need a manual for bulova watch C960600, can you help or at least tell me if it runs by battery?
Take it to any local Jeweler, they can tell you whatever you need to know about the watch.
Jul 13, 2016 | Bulova Watches
I have a fossil ES-1355 watch and it running slow. I installed a new battery and still running slow. Is there an adjustment I can make.
most batteries that run of a battery are controlled by a frequency crystal or electronic setting and is not adjustable
however take it to a watchmaker or jeweller as it may be adjustable using their instruments
May 15, 2016 | Fossil Watches
How can I replace the battery at a small cost?
You may have to find a jeweler who can remove the back.
Jul 21, 2014 | Ripcurl Rip Curl Detroit Steel A2227 Watch...
How do I replace the rubber on the back case of movado 800 series
I was told my a jeweler that Movado condiders that. Design defect and they don't produce or offer that rubber insert for sale.
Jun 26, 2013 | Movado Series 800 Watch
Bulova accutron 2 years old stopped running after jeweler replaces battery. You could hear a hum but it quit working. Cost to fix?
The first thing I would do is take it to another jeweler (preferably in a higher end store), ask how experienced he/she is with your brand of watch, find out if they are the senior jeweler in the shop and just get a feel of whether you trust their opinion or not. Explain to them what happened and ask them if they can tell whether or not the person who changed the battery for you could have caused the damage to your watch. If they confirm that the person who changed it likely or certainly caused the damage, ask them to write a note explaining what the original jeweler did to cause the malfunction and then call the jewelry shop and tell the owner what you have found out. If they get huffy with you and tell you to buzz off, you have to then decide how much trouble the watch is worth. You can always take them to small claims court, but most shops will back up their work and if you have solid proof that their employee screwed it up and you don't let them back you down, they will likely (eventually) make things right for you. Best of luck!
Jul 02, 2010 | Watches
How do you put the backing of the watch back on?
guess backs can be kinda hard. if u can push it on with ur thumbs and press it against ur leg(for padding) then u need a watch press and should take it to a jeweler other wise u might break the crystal
Oct 07, 2009 | Guess Black G10550G Watch for Men
Battery was replaced by a jeweler. Since that
As the jeweller is not a watchmaker, he/she even did not realise the watch is not working properly. It sounds like your watch is having jammed gear train or the jeweller did not know how to reset the watch. Go to this website: www.tissot.ch
If you will not find solution there, you will have to look for watchmakers help.
Rate me, please.
Jul 29, 2009 | Tissot Prc100 T22268631 Watch
Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Bulova Watch
Pierre cardin running fast
Not enough information. Mechanical or Quartz for starters. Runs fast probably means it needs cleaning and service. Probably not a watch worth doing that with. They use cheap movements that can easily replaced but jewelers are too lazy or expensive to take a cheap watch to. These use cheapo movements.
Nov 15, 2008 | Pierre Cardin Watches
Cant keep time
there is adjustment for that inside of watch or it just may need a little cleaning inside recommend take to jeweler and have serviced if you want to try cleaning at home simply take off back cover and clean with a little cigarette lighter fluid put little bit in wash around and drainout (do not soak) allow excess to evaporate out and replace battery and cover hope this helps
Sep 05, 2008 | Timex 27191 Wristwatch
Kenneth Cole KC4232 Wrist Watch Logo
446 people viewed this question
Top Kenneth Cole Watches Experts
Arturs Kalnins
Arturs Kalnins
Norman Worley
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
