Question about Maytag Neptune Washer
Washing machine walks while spinning
Already had bearing replaced but still wobbles badly during spin even though leveled
  • 275 Answers
How old is it? i remember mine was brand new and first day we used it did the same thing yours is, but they checked the back and they had to take some big screws from the back and it never wabbled anymore.
Posted on Dec 13, 2008
    Master:
  • 479 Answers
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. in washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
My whirlpool top load washer vibrates bad and will walk across the floor during the spin cycle even with no clothes in it. I replaced all the springs, the unit is level. I don't know what else to do.
Check the giant flywheel on the back of the drum. Sometimes, the legs that make it up start to corrode and break. When they do, the drum will wobble.
Feb 08, 2017 | Whirlpool Washing Machines
Why does the Drum spin erratic even without clothes in it?
might be a warped spin basket or the dampers could need to be replaced. could even be a bad spin bearing. if it was bearing, normally would be associated with a loud noise during the spin cycle though.
Feb 27, 2015 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Belt keeps coming off on my maytag neptune front load.help!
Is the rear pulley tight? If the rear drive pulley is not tight it will wobble during high speed spin and drop the belt. Only other cause I can think of for this would be the rear bearing starting to fail allowing the entire shaft to wobble. You would be aware of this courtesy of a very loud sound during spin though.
Jun 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Washer wobbles
Its the clutch and its causing the drum to spin unbalanced It will need replaceing and a new sealed bearing too
Please rate our help to keep the free service online ++++
Aug 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Jan 16, 2009 | GE Washing Machines
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
FRIGIDAIRE FRONT LOAD WASHER
sounds like a bad bearing to me
Sep 02, 2007 | Frigidaire FWTR445R
Washing Machines Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
