Question about Electronics - Others
Dezone a dvd player
I have a toshiba sd 4100 dvd player that I would like to dezone to read european dvd as well as us ones
  • 69 Answers
Under you system set up on the dvd player you will have to select the PAL (european) format instead of the NTSC format
Posted on Dec 23, 2008
Toshiba SDP92 portable multi region unlock required
Yes it is...I have 2 solutions for you, but they both cost money, I'm afraid:
http://www.slysoft.com/en/anydvd.html
http://www.dvdidle.com/dvd-region-free.htm
Both work by stripping out region coding from incoming and outgoing video streams as they come into your computer.
Mar 11, 2010 | Electronics - Others
When i put a disk in, it says disk error
Your best bet is to clean the lens with a commercial lens cleaner for DVD/CD. If that doesn't work the problem could get more expensive to repair, and since DVD players are cheaper to buy (some) than repair, you might want to consider that as an option.
Jan 31, 2010 | Electronics - Others
Panasonic DVD-A120U Problem with disc in player
either the laser is burnt out,or the disc motor is no good.
locate the peice that the cd sits on.spin it.if it reads the disc after,the motor is no good.
Sep 01, 2009 | Panasonic Electronics - Others
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
When I put DVd in sounds like its loading then I get disc error playback not on this disk
Several possible causes
1. Laser read lens dirty - clean it
2. CD has become damaged & data cannot be read (does it read in other cd drives?)
3. Intermittent malfunction of laser read circuitry.
4. Process of elimination - if CD is readable on other drives, the problem is with DVD player. If cleaning does not solve the problem, the problem is DVD internal electronics.
Jun 18, 2009 | Electronics - Others
Cd drive motor wont spin properly
...see if the laser lens not dirty and working fine...sometime if the laser lens can read the disk then the motor stop working...and in the information screen LED say "NO DISK"...
Apr 29, 2009 | Electronics - Others
Dvd player reads'' disk not read or no disk''
You have a damaged read laser. You can either send your unit in for service, if it is under warranty or replace it.
Jan 21, 2009 | Electronics - Others
Disc Read Error Sony DVD Handycam
I am just throwing these out there as food for thought. Make sure you ended the recording on that other side. If a DVD is left open(meaning more could be written to it) other dvd players have a hard time reading the info. Put in one of the 2 sided disc's that worked. how does the camera recognize the disc? Then insert the troubled disc and see if the disc info is being read the same. i.e. disk size, manufactuer, open/closed? Check for a firmware upgrade for your DVD burner/player(s). Let me know how things work out. Tim
Mar 05, 2007 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
Electronics - Others Logo
109 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
