Question about Syntax Olevia 50" Rear Projection HDTV-Ready Television
Broken bulb I need to find out where I can buy one
Havenadams@live.com you can go to olevias home page under support there is a 1800 number call them and order the bulb from them it is 100.00 dollars 10 dollars shiping thank
Posted on Jan 06, 2009
Hear a pop like a firecracker and then no picture
It is likely that the bulb has failed. The bulb can be removed as an assembly from the rear of the unit. Carefully inspect the lamp and confirm that the glass bulb has failed. the pop could be the bulb fracturing. Careful for broken glass. Suggest that you buy a direct manufacturing equivalent. I have found they are the brightest.
26120369-qhrtjxzbaepf4lgqc41ptsvr-3-0.jpg You can buy just the bulb or the whole lamp assembly as pictured above. I recommend buying the assembly
\The link is from the owners manual providing the instructions to replace lamp.
http://www.manuals365.com/swf/mitsubishi/638-c10_bib.html?page=28#manual
Hope this has helped?
Mar 06, 2016 | Mitsubishi WD60638 60" inch 3D Ready DLP...
Mitsubishi dlp tv won't turn on
My family's house once had a older model Mitsubishi DLP TV that went out (which I found out they are famous for). The problem was the projector bulb had died. Your problem is either that or a ballast problem (something more complicated that I do not know how to solve).
Open up the bulb housing on the back of your TV and check to see the condition of your current bulb. NOTE: the bulb housing contains mercury so handle with care. Also, if the bulb is broken/dead, there might be shattered glass sitting inside the bulb housing.
The only way to fix it was to buy a new bulb (search amazon for wd-65837 lamp" you will find a few results). This temporarily fixed our problem. However, for some reason, the aftermarket bulbs do not last anywhere near as long as the original one. So if you do end up buying a replacement bulb, buy something with a good warranty. If this doesn't work just send the bulb back.
Hope this helps!
Nov 10, 2012 | Televison & Video
I have a 1991 mustang gt all the lights work but no tail lights i dont know what to do? How do I diagnoise the problem?
You need to check your tail lamp fuse. See if it is blown. Of course, check the bulbs first though. see if that works. If not, it could be the switch itself, faulty wires, or bad sockets.
Feb 12, 2011 | Ford Mustang Cars & Trucks
700w carbon fiber heater bulb is broken, where can i buy a replacement ? Heater Mod #6318348. Price?
Jan 11, 2011 | Heating & Cooling
I have a Malibu ML300RTW and it stopped working. I checked using a tester. 120v is in, but 12v output terminals do not register any voltage. I heard that if I plug in and if it does not get warm, the time...
When power pack malfunctions, you have to buy another one
I have looked for solutions at Intermatic, at malibulights.com and the internet
Your next power pack:
Match up wattage of bulbs with wattage of power pack
15 - 20 watt bulbs = 300 watts
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out
-When working on bulbs, unplug power pack or it may burn out
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
Oct 31, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Bulb broken in socket
either you try to remove the bulb by long nose ( power cord unplugged) or buy the bulb and socket assy.
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Freezer broken lightbulb
you can usually take a potato and screw the broken bulb out and find a new one home depot lowes or walmart
Apr 24, 2009 | Magic Chef CTB1521 Top Freezer...
I need a BLUE bulb for this TV.. where can i get
Parts are Very scarce unless you buy a broken unit for spares. If you are interested in selling any of the optical components please email me. kievsavoie@hotmail.com
Feb 26, 2009 | Proscan PS80690 TV
Where i could buy a Bulb ?
try partstore.com, the lamp will come as an entire assembly. The whole case. just loosen the two screws and slide it out. You shouldn't have to do anything afterward, check your menu and see if there is a timer to reset, but aside from that nothing.
May 06, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
