Question about Carrier 38CKC042 Air Conditioner
What type furnace is a GUJ125V20-3A - Carrier 38CKC042 Air Conditioner
  • Allen Neal
    Allen Neal May 11, 2010
    can you post picture
  • Stephen Evans May 11, 2010
    can you get any further info off the rating plate. this is usually located inside the top door on the left side
  • 30 Answers
It is a 125,000 btu furnace are you looking for a brand as well?
Posted on Jan 05, 2009
T8677B1006 has no display
Without knowing the furnace type, it's hard to say if yours has a fuse (automobile type) on the furnace board that's bad or the low voltage transformer on the furnace is bad.
May 19, 2015 | Honeywell Programmable Thermostat Heater
Tip
Whole House Humidifiers ? The Types and Benefits of the Furnace Humidifier
As your gas furnace or other type of furnace heats the air in your house it will be forcing the moisture out of the air. To maintain the proper comfort and to keep things from cracking from lack of moisture you need to install a furnace humidifier.
Furnace humidifiers offer many health benefits. They help to relieve the irritation of breathing dry air. More humidity in the air has shown in studies to lead to healthier lungs and fewer illnesses. To many people, another very important benefit of installing a good furnace humidifier is that the addition of more humidity to the space during cold-weather months allows for you to lower your temperature setting on the thermostat while still maintaining comfort.
If you are already looking for a furnace humidifier, you are probably familiar with many of the great benefits of installing one in your home or office. A good furnace humidifier will also help alleviate some symptoms associated with asthma or allergies as well. A good furnace humidifier can also help you to prevent cracks in your precious wood. Another great benefit of installing a furnace humidifier is that it will help eliminate static electricity.
The three most common types of humidifier are bypass furnace humidifiers, the power spray furnace humidifiers, and also steam furnace humidifiers. The bypass humidifier seems to be the most common furnace humidifier is the bypass humidifier.
All of the different types of humidifiers need to have a lot of maintenance. On the pad type humidifiers you need to clean or change to pads often. On spray type humidifiers the nozzle and pad will need to be changed or cleaned yearly. On the best types of humidifier is the steam furnace humidifier. They produce the most humidity but are very expensive and do require more regular maintenance and upkeep then the other types of humidifier.
A humidifier can be a fantastic addition to your hot air heating system. The type of humidifier that you need to have will often be dependent on the size of the space you are planning to serve. Also, do you need precise control or not? Overall a humidifier is often a must have item if you are heating with hot air heat. Dry air is not any fun and causes many problems. Put up with the time you will need to invest in cleaning and servicing your humidifier. Having the proper amount of moisture in your house will pay you back many times over.
on Dec 12, 2009 | Heating & Cooling
I have a coleman modulating furnace it is propane The buners seem to be corroding
There are 2 types of burners. Atmospheric (or ribbon) type & inshot. I would imagine yours are Atmospheric...the longer type burners that protrude into the heat exchanger if they are corroding. Which also means you have an older furnace. Condensation can occur if there is not enough removal of flue gas...or... water is getting down into the burner from the flue. Have someone check the draft pressure to see if it has a proper draw when running. Coleman Evcon also made a furnace that is called a blendaire system. This system has a lower control board @ the furnace & and upper control board in a fan on the roof. The purpose of the fan was to blend air into the return from outside via roof fan to introduce fresh air in a tightly enveloped manufactured home, along with pressurizing the attic space to help keep the attic dry. If you have this type of system, your motor may be not working on the roof. Good luck!
Dec 02, 2014 | Heating & Cooling
How do I tell if thermostat isn't working?
You could short out the thermostat wire connection points or do so at the furnace but you need to advise what type and make etc of furnace you have, is it a thermocouple type (old), a new mid efficiency type with igniter coils etc or an igniter elemwsnt or a newer higth efficiency type????
Oct 04, 2014 | Home Security
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Furnace repair
By not knowing much, I would think that maybe the gas is coming out, but not igniting. I would also need to know if it is working, and heating up your home. If the it is not igniting, than it would not be working. Something may just be caught in it., be sure to check the filter.
http://www.marylandoilco.com/Furnace-Repair-Dundalk-MD.html
Dec 03, 2013 | Heating & Cooling
The furnace control on a York furnace is locking out due to unable to ignite flame
possibilities are many, no spark due to ng ignitor, if draft induced , fan not coing on or has blocked flue, if unit is condensing type might have condensate in drian line, if standing pilot type thermo couple bad so not sensing pilot. so you see not enough info of what type unit you have to help narrow down possibilities
Nov 12, 2013 | Heating & Cooling
Heater doesn't come on?
The electronic ignition system in a gas furnace is a modern development that allows more reliable performance than standing pilot furnaces, provides energy savings and contributes to better furnace efficiency (AFUE). With a standing pilot, found most commonly on older low efficiency furnaces (55% to 65% AFUE is not uncommon), a small gas flame is always burning and is known in the lexicon of American home repair as a "pilot light". The problem with this type of "analog" ignition is that it wastes energy by constantly burning gas and can sometimes be unreliable. These issues have led to the development of electronic ignition systems for mid to high efficiency furnaces that exceed the U.S. government's established minimum AFUE rating of 78%. The electronic ignition occurs typically in one of two ways:
  • Intermittent Pilot, or
  • Hot Surface Ignition The intermittent pilot system uses an electronically controlled high voltage electrical spark to ignite the gas pilot and then subsequently the main burners, when the thermostat calls for heat.
    The hot surface ignition system uses an electronically controlled resistance heating element not unlike a light bulb filament (and shown in the photo above), to ignite the gas burner.
    It is important to understand some of the other components of a modern furnace that you will encounter depending on the type of high efficiency furnace you have. Why? Because they can also come into play in repairing an electronic ignition furnace when it won't run properly. Let's take a quick review of the types of furnace designs and components found in high efficiency furnaces using electronic ignition.
  • Nov 14, 2010 | Goodman GMS90703BXA Heater
    Main blower stays on, burner fan on intermitantly,
    All gas furnaces have a fan control of some sort. Either a mechanical fan control where there is a temperature probe that reaches into the heat exchanger compartment thru a hole in the panel that separates the control part of the furnace(this would be the front of the furnace where all the controls are) from the heat exchanger. This type of control is either a small black plastic control about 4 inches by 2 inches and about 1 1/2 inches thick secured to the panel with 2 screws. Or it is a slightly larger silver colored control that should have a pull off cover. It may say Honeywell on it. Either way the control will need replacing.
    The other type of fan control is a solid state control board. This will most likely be located in the indoor fan compartment. It should be located under a covered control box. The box with all the wires going into it. This board will also need to be replaced if your furnace uses this type of fan control. You will need to bring your furnace model and serial number to a dealer that sells your brand of furnace or go online to a parts dealer that carries parts for your furnace. Hope I was of help to you! Good luck!
    Nov 28, 2009 | Heating & Cooling
    Carrier 38CKC042 Air Conditioner Logo
    43 people viewed this question
    Top Carrier Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Bill Long
    Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
