Question about Sunbeam Heritage 2346 Stand Mixer
Sunbeam 2346 it make growling noise when i start to beat.How do you tear it a part.
I just did it. Get your digital camera and take pictures along the way so you'll know how to reassemble it.
On the front of the mixer, there is a chrome Sunbeam sticker. Use a pocket knife, slide it under the sticker and pry/peal it off. Then you will see a single screw that goes into the guts of the mixer. Unscrew it and remove the front of the mixer. You'll then see two screws that keep the top of the mixer on. Remove those and you can undo the top housing.
You take off the back of the mixer in a similar manner. Use a screwdriver to pry off the chrome cap on the back, then remove the single screw and the speed control will come off.
The gear box just above the blades is a potential area for the growling. It is pewter colored metal held in place by four screws. Clean out the old grease and replace with new (NOT oil, grease, like axle grease or lithium grease).
Use a toothbrush to get the old dust and flour off the innards of the machine. I also used a can of compressed air to blow it out and sprayed the electrical contacts of the motor with WD40.
Mine works like a champ now. Took about an hour.
Posted on Feb 03, 2009
Sunbeam heritage series 2346
Some lubrication might be in order. Grease will dry out and cake so it won't lubricate what it's meant to.
Dec 12, 2016 | Sunbeam Food Mixers
Need manual for Sunbeam model 2346 stand mixer
Sunbeam has the manual for the 2346-33 stand mixer on the product page: http://www.sunbeam.com/ca/productdetail.aspx?section=kitchen&cid=14&pid=5280 . The direct link to the manual is http://www.sunbeam.com/ca/manuals/Sunbeam/002346-033-000_English.pdf . The manual covers several models. Note: you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 16, 2011 | Food Mixers
Bowl does not rotate anymore
This is typical of Sunbeam mixers. The solution is to throw that piece of junk out and never buy anything from Sunbeam again. They can't stand behind their products because they know they are junk. They would go out of business if they tried to repair/replace all of the useless appliances they sell.
Oct 24, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl wont rotate
How can i get a replacement manual for the sunbeam mixmaster heritage series 2347
You can download the manual from the manufacturer's web site at
http://www.sunbeam.com/Manuals/MANUALS/002347-030-000_43_32347182.PDF
Feb 25, 2011 | Sunbeam Heritage 2346 Stand Mixer
Vintage Sunbeam Mixmaster MXG makes a strange noise and has a burning smell when operating. Is there anyway I can fix this?
the motor is burning out at the coil you can send it into a electric motor re winder but it could be expensive look them up in your local directory
Jul 04, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Jan 08, 2009 | Sunbeam Heritage 2346 Stand Mixer
Slow speed,won't wip eggs,
Yes, the solution with the lleast amount of resistor...I mean resistance is .. get your wife to beat your eggs for you while you sleep ,.
Dec 17, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam 2436 not working properly
did you mean model 2346? If you did, I am having same problem
Dec 17, 2007 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam Heritage 2346 Stand Mixer Logo
575 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
