Question about E-Machines M6811 Notebook
E MACHINES LAPTOP
HOW AND WHERE TO FIT MEMORY
  • 340 Answers
Hi Andy,
turn your laptop upside down.
here you find a lid (8x11cm), with one or two screws.
remove this/thise/, lift the lid, bingo :-)
regards
/Teis
If this was helpful, do vote before you leave,
Thank you
Posted on Dec 13, 2008
  • Teis Thomsen
    Teis Thomsen Dec 14, 2008
    Hi Andy,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if its Fixed, then vote to close this case,
    Thank you
    /Teis
How do I replace the 4 GB memory module with an 8 GB module?
I need to know if your laptop supports 8GB and is it 64bit. If not 64bit the machine cannot use more than 3.8GB. If it supports 8GB remove the 4GB chipe and fit the two new 4GB chips. They must be exactly the same or you will have problems.
Jan 15, 2016 | Computers & Internet
I need to remove the keyboard to fit new memory how do i do this please
You do not remove the keyboard in order to fit your memory (Ram). You have to unscrew the bottom panel of your Laptop. Some laptops come with a section where you open at the bottom so that you can have easy access to fitting in memory. There is usually two panels at the bottom one for the Hard drive and the other for the memory. if you do not have this you then have to unscrew the whole bottom to get to the motherboard and then the memory itself.
Oct 20, 2011 | Computers & Internet
How to remove memory chip
Most notebooks have a memory access panel on the under side of the unit. Unscrew the fastener and you'll see the memory modules. These are held in by metal leaf springs on either side. Pull these away from the module and the module will move up. Pull the module out and reverse the procedure when fitting new memory. Make sure the laptop is turned off and unplugged, and make sure you are grounded whilst removing and fitting memory modules.
Zahc
Jan 26, 2011 | Acer Aspire 3624WXCi Notebook
How do i store pictures to memory card then upload to my acer laptop. Memory card is to small to fit any slot. This is on a sony ericcson vivaz
You have 2 options. You can connect the phone to your laptop using the micro usb cable. It has a narrow plug which fits into the phone and a wider one which fits into the usb port on the laptop and should have come with the phone. The other option is to buy a card reader for your laptop. These take lots of different types of cards and plug into the usb port on the laptop. The memory card with your phone is a Micro SD card so make sure the card reader you buy is reads these. The card readers are available for around 10 euros from places like Tesco or from computer shops.
Jul 14, 2010 | Computers & Internet
Need help with my laptop
Can you be more specific? That doesn't make much sense? Are you asking if all memory fits in your laptop? The answer to that is no. It depends on your machine. Google the laptop model and memory.
Jan 05, 2010 | Compaq Computers & Internet
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Will my memory card fit in my laptop
usually a sd slot says sd by it ? if it fits givre it a try,,dont force it. what model is it?,check the support web site.and read the documentation files
Sep 02, 2009 | Computers & Internet
Latitude C800 Memory slots
Go to www.crucial.com allow their program to run on your machine and it will give you a report on what memory you can fit
If you are in the UK it is www.crucial.com/uk
More to the point it will tell you what is the maximum memory the machine will take
Crucial also supply memory at good prices and to date nothing they have supplied me with has failed to work
Jul 03, 2009 | Dell Latitude C800 Notebook
New RAM to be fitted
The memory compartment is on the bottom of the Aspire 3003, the square cover in the center towards the front edge of the laptop with two fan vents. It should be secured with two small philips screws.
Dec 28, 2008 | Acer Aspire 3003LCi Notebook
Where do I install memory module
usuall memory module is on bottom of lap top you need a screvdriver to open small door,and then you see old memory module.insert new,and !!!!!!!!!!!!!!!!!!!!!!! when you do that pull up the batery and remove charger from laptop
Feb 07, 2008 | HP Pavilion dv6000z Notebook
E-Machines M6811 Notebook Logo
51 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
