Poloaroid 42' LCD tv wont come on
Model TLX-04244B Just opened the box plugged it in and the screen jumps on for 2 seconds and goes black like its shorting out. What could be the problem?
  • casper40 Dec 14, 2008
    The Light Stays blue.
  • christy84 May 15, 2009
    I was watching TV (42" LCD Poloariod TLX-04244B) and the tv turned off by its self. Now the tv just goes black. Can any one help I got the tv on 11-08 and now I can not get a hold poloariod for repair.
  • 51 Answers
I know this post was a long time ago but in case anyone has the same issue. I bought a TLX-04244B "as-is" for $150 with the same exact problem. Turn it on get to the polaroid screen for maybe half a second then it sounds like it's shorting out and shuts right down. I found the problem to be on the power supply there were actually 2 ??? (not sure of the part name, resistors maybe) that were so close together that they were actually touching. I separated those 2 turned it back on and been fine ever since. As far as Polaroid and warranties go, you must call Proview tv's warranty support line. These tv's are made by Proview Polaroid only licenses out their name to Proview, I would imagine that's because Proview's tv's are such junk they need to use another name to peddle their substandard chinese ****. Be prepared however, although your warranty says in home service they will tell you that you must ship it to their service center. They will supposedly pay the shipping costs but beware and please check out all the consumer reports about people sending in their tv's and never getting them back. They seem to just get the run around for months on end. If your tv is new enough I would highly recommend returning it to the retail store you purchased it from. I have 1 functional and 5 dead Polaroid tv's at this moment, I buy them broken they are easy to fix yourself but if you do not have the know how then stay away from these tv's because IF your tv lasts 1-yr you are lucky.
Posted on Aug 22, 2009
  • elderisaac
    elderisaac Nov 07, 2012
    Hello, i jsut got this same model tv for free!! i'm having the same problem. i was wondering if you could contact me so that i can get more detail on how to fix it.
  • 4 Answers
Well if you get a screen that shows the polaroid logo with a bright ble screen then goes to black...some q's to answer for me ....does the power indicator on the lower right front of the tv go red,stays blue,or goes out completly??
Posted on Dec 14, 2008
  • bulldog80 Dec 14, 2008
    well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....
Polaroid 42 LCD TV - Backlights turns off after powering on
The back light LED array is faulty. May be it would be difficult to get the LED Array Because its comes withe the LED panel. Try to consult Polaroid service center.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 08, 2016 | Polaroid Televison & Video
What happened to my color on screen?
I experienced a similar problem with my 52" Sharp Aquos TV. I called and spoke with Sharp service dept. and they walked me thru the process of resetting the TV to it's original "default" values. It worked great once I completed the steps while on the phone with them.
suggest you do the same thing with JVC.
Aug 15, 2014 | LG 42LC2D 42 in. LCD HDTV
Poloriod tlx-04244b sceen will not come on
if their is a sound with totally black screen the cause would be either inverter board get bad or the screen back light was damaged. if just a white screen, you can noticed by looking at the dark room. then the cause would be bad t-con board. just let me know if it can help you can ask further solution thanks for consulting through fixya.
Nov 04, 2012 | Polaroid FLM-4201 42 in. LCD Television
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
Last night I turned my Polaroid TLX 04244B off, and had zero problems. This afternoon, I have a 6" pattern of horizontal lines across the right hemisphere of the screen. They come and go, darker...
You are probably seeing hum bars which may be due to an AC ground loop that is going through the shields of one or more of the cables inteconnecting the TV with one or more of the other video components. You should do the following to try to resolve it...
1. reseat all the interconnecting cables between TV and other units
2. have all AC power supplied by one power bar with a ground plug
Mar 17, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
Screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
May 25, 2009 | Polaroid 4226TLMB 42 in. LCD TV
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
Nov 28, 2008 | Polaroid FLM-4201 42 in. LCD Television
Can't get all cable channels
Chech with you cable company to see if they switched to the higher chanels. I do not know if you are connected directly to the antenna or a cable box.
Televison & Video Logo
950 people viewed this question
Top Televison & Video Experts
