Question about RIM BlackBerry Curve 8310 Smartphone
Want to send picture from phone to computer
Phone says connection failed to computer even though it is shown as a paired device
    Problem Solver:
  • 7 Answers
Can you not use bluetooth to send pictures from phone to computer. Search on your mobile phones menu to see if there is bluetooth and enable it. If your mobile is not bluetooth enabled, you may still be able to send pictures from phone to pc if there is a USB cable slot in the phone. To send to the pc via bluetooth, either your pc has been set up with bluetooth, or, if not, you have
to install bluetooth using a bluetooth dongle which comes with CDrom, and may be purchased from computer stores like Currys or online for £10-15. Let me know if you have bluetooth, and I'll help you more. Once there is Blue tooth it needs to be turned on, and discovery mode has to be enabled, (not disabled) in order to communicate with other nearby bluetooth enabled devices. Get back to me tell me what you found out, Good luck papertigers
Posted on Dec 13, 2008
Bluetooth failed to connect on a sucessfully paired z221 device. fix?
You should use Accessories - Bluetooth File Transfer from your computer to send or receive files
Jul 02, 2012 | AT&T Cell Phones
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I am having problems getting pictures send to my Blackberry 9000 via Bluetooth from Nokia and other phone devices. Even though the device is paired with my Blackberry sending pictures fails (with error...
hey hi...may b i can solve ur problm...
1st open d media application,then lighlight the picture folder by putting the cursor on it.next click on the menu of the picture folder.....there u will find a option "receive through bluetooth".click on that.ucan receive ur files nw.
(Note:-u mst 1st swith on ur bluetooth and must have paired wid the device 4rm which u wish to receive data)
only after clicking on the "receive through bluetooth" the data must b send 2 the blackberry.....
hope u got it....
u can contect me at zeebonbarua@gmail.com 4 quarries..
gud luck
Aug 03, 2010 | RIM BlackBerry Bold 9000 Smartphone
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
Jul 10, 2010 | LG GW300 Cell Phone
I have a LG Vu and I want to use the bluetooth setting to download photos into iPhoto. How can I do this? I have tried and tried to no avail, my imac book still shows no connection. Help me please!
What you do is find the bluetooth symbol at the top of your screen (the background) then go to SETTINGS and then to DEVICE VISIBILITY (should be the very top) hit the ON choick then OK for other bluetooth devices to recognise it. then go back to the MAIN BLUETOOTH MENU (just hit back button) and go to SEARCH NEW DEVICE (second one down) but make sure you are in the same room as your computer to have your phone connect with the computer. That should then find your computer and then REQUEST TO PAIR (just touch the name of your mac) and then ENTER THE CODE (should be four zeros if you didnt change it and do the same thing on your mac then after that just select the photo you want to send and hit SEND VIA BLUETOOTH and select your mac
Jun 29, 2009 | LG KU990 Viewty
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
299 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
