Question about Square D Ehb24020pl 20 A Ehb4 Ehb Circuit Breaker
High amp start up draw
I have a Craftsman 2.5hp radial arm saw. When trying to use it on a 15amp circuit (as the manual says) it doesn't come up the full speed and trips the circuit after running about 20 seconds. In checking the draw on the line I found the motor pulling 39 amps on start up and I show 123+ volts on the line. If I plug into a 20 amp circuit it comes up to full speed in about 5 seconds drawing 39 amps then dropping to 9 amps when reaching full speed, line is showing 125 volts Thoughts as to why?
  • 4 Answers
6kw what!!!! more like 1.08kw the saw is fine
Posted on Oct 08, 2009
  • 653 Answers
All electric motors require additional power to get the rotor up to normal operating speed. The amount of current that is required depends on the starting load, in this case the weight and inertia of the blade itself and the moving parts of the motor. Motors that have very high starting loads, like a shop compressor for example, usually have one to three capacitors mounted to the motor to provide the additional starting power. If the owners manual specifies a 15 amp circuit and the saw doesn't work, I would check to see what else is on that particular circuit. If there are no other loads on the circuit and it still trips, you need to have the saw motor checked before it burns out.
Posted on Feb 26, 2009
  • Fahr Quad Mar 13, 2009
    So did you have to get the brushes in the motor replaced???
  • 5,568 Answers
I don't care what kind of stories Craftsman tells, their numbers don't add up.
One horsepower is ~ = 740 watts of energy.
2.5 hp equates to a steady-state power consumption of  ~1850W and this could be 50% higher during the first second or two after turn-on.  Your 15 Amp circuit is pushed to the limit by that power level; 15 Amps X 120 VAC = 1800W And, motors aren't a breakeven game; part of the power they draw is wasted in heat.
9 amps steady-state would be a power consumption of over 6kw which cannot be right. Either your measurements or the motor is faulty.
Posted on Dec 15, 2008
Model #113198611. Where can I get a user's manual?
If you have a Craftsman 113198611 Radial Arm Saw, Sears Parts Direct has the manual available from their product page: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/user-manuals/manual-downloads/Model-113198611/0247/0744500?modelNumber=113198611&diagramPageId=&documentId= . (Just search for the model number and click on the Manuals tab.) There are two manuals listed here. The first one is for the guard and the second one is for the radial arm saw itself. The direct link to the saw's manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0803542.pdf .
I hope this helps.
Nov 16, 2015 | Saws
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
Need a manual for an old Radial Arm Saw, Craftsman...
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you to a series of available parts drawings and hopefully, the manual. Good luck!
May 20, 2010 | Garden
Need help locating a manual for an old Craftsman saw
Go to Searspartsdirect.com and list the complete model number minus the decimal point. You will get a series of drawings listing all of the replaceable parts and hopefully, the manual. Hope this helps!
Apr 29, 2010 | Saws
Craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
Apr 04, 2010 | Craftsman 10" Table Saw
I just bought a Sears radial arm saw. Model
Go to searspartsdirect.com and list the model number which brings up drawings of all parts and usually a manual. Hope this helps!
Feb 05, 2010 | Saws
Radial saw motor just buzzes.
It sounds like the start circuit is shot on the motor of the radial saw. It is trying to start, (the buzzing sound), but the start is not is burnt out, and therefore the run winding is drawing excessive amperage trying to start the motor (a job it is not designed to do) and eventually builds a amp draw in excess of the circuit. You will have to determine which is cheaper a new motor, or a new saw.
Hope this helps
Sep 25, 2009 | Saws
I need a diagram of a Craftsman Radial Arm Saw base
I persevered and finally solved the jig saw puzzle of pieces. The base is now assembled and just waiting for the saw body to be remounted. Thanks everyone for looking at this post.
Sep 05, 2009 | Craftsman Saws
Square D Ehb24020pl 20 A Ehb4 Ehb Circuit Breaker Logo
821 people viewed this question
Top Square Electrical Supplies Experts
Steve
ken skalski
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
