Rumba Macro Help
Hi all, i was wondering if anyone knows a way to have a Rumba macro run and place the cursor on the first blank line that is available. My Rumba setup will have 10 lines, with some filled in. I was wondering if there's a way to have the macro check the line and if it's got text to move on to the next line and check it.....TIA
SeaJade
  • 104 Answers
SOURCE: Macro through excel
What did you actually want to do with it as Macro VBA coding is rather large?
Posted on Oct 28, 2007
  • 171 Answers
SOURCE: macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Posted on Jan 28, 2008
PCBuilda
  • 101 Answers
SOURCE: Excel Macro to find out non-keyboard ascii characters
Not a macro but if you need a particular code for a symbol. Try Start button and then run
type charmap
You will find all the symbols here and in the bottom right hand corner it shows the keystrokes for selected symbol.
Posted on Mar 20, 2008
  • 359 Answers
SOURCE: Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Posted on Apr 21, 2008
welcomejee
  • 10594 Answers
SOURCE: iNVALID Macro
Select Macro option ON and try.
Posted on Jun 03, 2008
I want to know about macros
you can find more information about macro and usage of macro from
Automate computer tasks easily with macro software
Oct 29, 2010 | Computers & Internet
How do I set the macro setting on a Canon Powreshot A610 and how can I switch of the flash?
Press cursor-down to toggle the macro setting.
Press cursor-up to cycle through the flash modes.
The flash modes are described in the "Using the Flash" section of the Basic Guide (page 9 in my copy) and the macro mode in the "Shooting Close-ups (Macro)" section (page 10). If you need the manuals, you can download them from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a610#BrochuresAndManuals
Aug 19, 2010 | Canon PowerShot A610 Digital Camera
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
May 16, 2010 | Rokinon 85mm f14 for Nikon
What do you mean excel macro
is a hiden process of Excel, is like program or several steps ( like moving cursor, make calculations, moving files, is no limit what can do, but normaly is not visible, is low level programing is always used for virus spreeding.
Jan 14, 2010 | Computers & Internet
I have never run a microsoft outlook macro. there is one set up in the laptop i use at work, are there any printable instructions i can print off .........i don't want to ask anyone at work for help.
Running a macro is simple: Select Tools | Macros, choose Macros from the resulting submenu, select the macro you want to run, and click Run.
May 06, 2009 | Computers & Internet
I can't get my Powershot S5 to go into Super Macro mode - Help!
There seem to be two stipulations for getting into super macro mode,
First you must be in scn ("A" or "S" mode's only) and "movie", "P", "TV", "AV" or "M" modes only.
Secondly the zoom Lens must be all the way out.. set at the widest angle.
Best of luck
Jun 14, 2008 | Canon PowerShot S5 IS Digital Camera
Macro
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
Regards,
TheAssembler
May 06, 2008 | Microsoft Excel for PC
HOW TO USE MACROS
Dear ROCKY open Tool Menu-Macro-record new mecro-give the macro file name like rocky-do your work when you finish your job then stop button mecro and save it . next day when you do same job on other file then again open macro and run your macro file and get same job on your new file
Sep 20, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
580 people viewed this question
David Payne
David Payne
