Question about Fuji FinePix A345 Digital Camera
I don't know how to erase my memory card.
I lost my user guide and dont' know how to erase my memory card. help!
1) move left hand toggle switch all the way to left, where the little playback sign is, where it lets u look at the pics you have.
2) Press menu button once - you should see a red box with erase at the top. use your zoom toggle switch to to select "all frames"
3) Use the menu button to select ok
Card should be erased.
Posted on Dec 19, 2008
How to erase memory card on CanonSX12 IS
Go to the camera's Menu then scroll through the o Format memory card.
Apr 10, 2013 | Cameras
I have a digital camera 4.1 megapixel i can not get my photes to show dont know if they were accidently erased or not please help me find my photes and get my camera to take photes correct again
Hi
Take the memory card out of the camera and try to read on your computer through a memory card.You might find the photos you are looking for. If your memory card is good you can try to recover the erased photos using the recovery software which are easily available. As far as the camera is concerned you have not mentioned what is the actual problem, so i will not be in a position to give a solution for that.
Regards.
PLZ. don't forget to rate my solution.
Jul 14, 2011 | Cameras
I need the user guide for my Vivicam 8340 digital camera, since I want to install an SD card on it but I don't know how to do it. Thank you, in advance!
The user guide is not available online as a download. However installing an SD card is usually pretty simple. On this camera, the SD card slot is on the bottom inside the compartment where the battery is housed. Simply slide the door open, and locate the slot for the memory card. The memory card should only go in one way, so don't try to force it. If it doesn't fit fairly easily try turning the card around. Remember: the gold pins on the card go into the camera!
May 05, 2011 | Cameras
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
How to erase all images from Canon Power Shot S-500 memory card
Do the following:
Play button >> Menu >> scroll down to Erase >> scroll down to All images .
Here is also the user guide: Camera User Guide
Feb 17, 2009 | Canon PowerShot A520 Digital Camera
Accidently deleted pictures in format.
yes, it it possible to recover lost photos from digital camera, either after they are been deleted or memory card is formatted. Please follow the steps in this digital camera recovery guide that helped me last time.
Jan 08, 2009 | Kodak Easyshare C813 Digital Camera
Things i dont know in using motorola v3i
for erasing messages you should click the button that is in the middle, at the top of all buttons of the phone.. then you will see the options you can select, between them, there is "erase", you can choose to erase them all, or just the message you were reading..
don't know is themes can be dowloaded.
for the pictures it is quite the same, if you go to options, using the same button, then you can choose something like "use different memory device" and if you choose that, you can choose between the intern memory of the phone and the memory card you are using..
I hope this was a bit helpful.. Can you rate this solution please??
Dec 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Deleting photos of my camera
Your camera creates folders on the SD card to hold the images. It puts about 100 images in each folder. (See page 111 in the User Guide.) When you erase images, it may only be erasing the images in one folder. But your computer still sees the images in the other folder(s). To completely erase all images, use the "Format" function (see pages 25 - 26 in the User Guide). To completely clear it, use the Low Level Format option. You can download the User Guide here.
Aug 27, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Fuji FinePix A345 Digital Camera Logo
61 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
