Question about Poulan Pro Chain Saw 46cc 20"
Runs bad like no fuel
I have checked the filter. changed the fuel. It has very little run time because I have had trouble with it from day one. when I pull the rope it is very hard and I have replaced the pissy plastic piece three times. I think your products are trash.Can you help me,This seams to be a common problem with the 46cc 20 inch model. Maybe you should return all the people who bought this piece of **** their money. just to keep your custoners, because I may never by another product with polan written on it.
  • FLMUSTANG Feb 27, 2009
    POULAN MODEL 2075 16 IN.REPLACED ALL NEW FUEL LINES NEW FILTER PUMP THE PRIMER BULB FULL OF FUEL RUNS FOR A SHORT TIME. FUEL LINE EMPTIES .REPRIME THE BULB AGAIN .RUNS AGAIN FOR SHORT TIME STOPS!
  • 32 Answers
Well assuming this is your model:
runs bad like no fuel - getimage.php?m=pp4620avx&s=s&t=chainsaw
Chain Saw PP4620AVX 952802146
  • 46cc 2-Cycle Gas Chain Saw
  • 20" steel bar
  • Anti-Vibe Handle
  • Automatic Chain Oiler
  • Super clean air filter system
  • Tool-less Chain Tightening System
  • 2 Year Warranty
I would go to Poulan Directly and Voice your Complaint with them, they might make it right with You...
You can Contact them at:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1.800.554.6723
or Via email/request form:
http://www.poulan.com/poulanpro/contactUs.do
Good Luck!
Posted on Jan 18, 2009
04 Ford Expedition trouble accelerating.Struggle to get to 30 mph Engine light with code p0174 system too lean bank 2. P0172 system too rich bank 1. What to fix?
ok............when you change plugs the cmptr needs to relearn firing order. it takes 3-5 times/restarts before it relearns. I went through the exact same thing with my expedition. a day or two later she purred like a kitten. secondly if you are having acceleration problems you may be looking at a bad catalytic converter. lastly......check your air filter, take it out and see how it runs without filter. that was also an issue I had when it was rough running. good luck
Oct 12, 2017 | 2004 Ford Expedition
2002 chevy tahoe was running fine from pa to sc we filled with gas and a little while later the car sputtered and shut off did it 3 times till we got to georgia and got more gas then didn't do it until 4...
it is a distinct possibility as some dealers use a E added fuel to rip motorists off. It is also a possibility that there was water in the fuel so I would have the fuel filter changed as a precaution. Run the fault codes to check for reported faults.
Aug 01, 2014 | 2002 Chevrolet Tahoe
It cut off, but we were able to restart it. It cut off again and now it won't restart
If it's been sitting a long time with no fuel stabilizer in it, then yes, could be dirt and bad fuel causing trouble. Plus possible/likely plugged filter as well. You need to get that flushed through and add fresh/clean and new filter to start with. Perform a fuel pressure test before changing filter and if it's up to spec, keep flushing it out with old filter until done, and fresh fuel put in, then change filter.
Feb 14, 2014 | 1994 Plymouth Grand Voyager
I have a 1999 ford f-350 running bad. i have changed the fuel filter,air filter,spark plugs, 7 coils, and mass flow air sensor, still runs bad after running 10-15 minute. stuttering & sputtering. i...
The basics for a rough idle, you check for a leak of some kind. Fuel--egr--vacuum leak, something of that nature. Did you check for applicable trouble codes before changing any parts?
Jan 17, 2018 | Cars & Trucks
What causes a 1994 chevy pickup with 350 motor to surge at idle then die. Has little power, runs rough, bad fuel economy. disconnected egr valve, no change, replaced throttle position sensor, no change.
is the check engine on? are there any trouble codes? one posible cause would be a restricted fuel filter, a worn fuel pump, or a restricted exhaust system.
May 03, 2011 | Chevrolet C2500 Cars & Trucks
Having trouble starting my 97 maxima se, takes a couple of times before the car starts...runs fine after it starts...replaced the fuel filter with no change...what can it be?
i had the same trouble. i had a few fuel injectors leaking down,after setting a little while. changed them and it fixed the problem.
Feb 10, 2011 | 1997 Nissan Maxima
97 jeep wrangler 2.5 auto, backfire and loss of power on warm day
COULD BE DIFFERENT THINGS BUT I RECOMEND TO HAVE IT CHECK WITH A GOOD SCANNER TO FIND OUT TROUBLE CODES BEFORE BEGIN SPENDING MONEY
Sep 24, 2009 | 1998 Jeep Wrangler
Will 87 s15 2.8l throttle body sorta run if fuel pump bad? changed fuel filter it was totally cloged. fuel ran out line with filter off- key on. engine will run a little. dont wanna waste time and money on...
If the punp is bad it won't run at all. Check the throttle body injectors to see if fuel is coming out of both injectors. Sounds like one of the injectors is not working. If one is not working you can check to see if it is the injector or wiring by switching injector wires and see if the problem changed from one injector to the other.
Jul 18, 2009 | 1987 GMC S-15 Pickup
1996 Olds Aurora will not start.
It could be many things, heres a list of basics you could check.
  1. wore or lose drive belt
  2. bad alternator
  3. bad battery
  4. clogged fuel filter
  5. bad fuel pump
  6. clogged fuel injectors
  7. faulty spark plugs or spark plug wires
  8. check the timing
  9. faulty ignition coil
  10. clogged air filter
  11. battery terminal connections loose or corroded.
Mar 06, 2009 | 1996 Oldsmobile Aurora
Poulan Pro Chain Saw 46cc 20" Logo
197 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
