Back to:
Tags:
Denon DHT500SD System
Known issue ?
posted by Crowny on Mar 12, 2007
Hi
Terribly sorry to trouble you, but my machine has just passed 2 years old (do these things have a timer against the warranty !!!) and has started to go wrong
Randomly, the LCD front display comes up with PROTECT and the system shuts down
Can not happend for 8 hours, then will do it 5 times in 2 minutes
Anyone else seen this problem before ? Is there a simple fix ?
I really dont want to have to take it in for repairs, I havent got any speakers on my tv and i route everything through the Denon. If I take it in somewhere I wont have any sound on my TV !!
Many thanks in advance
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 13, 2007
Helpful (85)
Duncan
Rank:Guru Guru
Rating: 85%, 176 votes
My best guess from what you have said is that you may have some speaker wiring shorting (or bad speaker) or else you have a bad output transistor or a poor solder connection in the output amp area. If it isn't the wiring/speaker problem but the other then you will most likely need to see a repair guy to get it fixed. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Known issue ?:
I don't want to Accept this solution
Can you Help with these Home Theater Systems problems?
When I play the TV through my Denon 500SD system...
Hi I have a DENON ADV-500 SD reciever,when i put discs in...
Its been fine up to this week but not saying No Disc when...
My DHT500SD has suddenly started switching itself between...
Power light is on but it is stuck in standby mode
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
