Question about Belling XOU252 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Belling buit in electric oven model XOU 252 ovening was working went to check food oven had gone cold. Temperature and oven light are illuminated. Tested the grill that heats up, could the problem be my oven element. Why would it suddenly stop working?
    New Friend:
  • 4 Answers
Need new element that is element code "AB20" from link below you need to remove 2 screw or nuts that holds back plate element is behind it then pull oven out remove back cover remove element wires and put every thing reverse order
element code is AB20 link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
Posted on Dec 24, 2012
  • Belling Master
  • 3,463 Answers
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Posted on Dec 13, 2008
    Problem Solver:
  • 4 Answers
Or your timer could be at fault, either in auto or time of day not set... or nothing at all. your timer drives your main oven you see,,, if none of these defo the element
Posted on Dec 19, 2008
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 11, 2010 | Belling XOU252 Electric Single Oven
No Power to Belling 163 model
check the safty cut out, if there is one
May 16, 2009 | Belling XOU252 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Belling oven xou 179
Hi
you need to remove back panel in oven. from there you will see the element somtimes you can unscrew them from inside if not you will have to remove oven from housing . remove back panel and the element will be bolt from behind just remove these the refitt new element in reverse order. hope this helps you
regards dan
May 19, 2008 | Belling XOU174 Electric Single Oven
Belling XOU252 Electric Single Oven Logo
521 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
