Question about Leviton 104-05611-2WS 15A Decora Single Pole Illuminated Switch with Ground
My tenant was complaining taht he was getting a shock when he touched a Leviton 104-05611-2WS 15A Decora Single Pole switch for a bedroom closet. My problem is I now cannot figure out how to reconnect the switch. This afternoon I hooked it up and it worked except that this closet light had to be on for the 2 bathroom(s) lights to work and the kitchen as well. I have never seen this problem before. The switch box has two black wires on the left side, one top and one bottom. There is also a black wire on the right side top. There is a ground as well as white wires. When I opened the switch plate to look at the wiring, there were only black wires connected to the switch. Every attempt of me connecting the wires to the switch only get me the result of having to need the closet light on for the lights in the kitchen and baths to work. Totally confused.
    Scholar:
  • 127 Answers
The three black wire are as follows: One is the hot wire. One feeds the closet light. One feeds the lights for the kithen and bath. Turn off the power at the circuit breaker or fuse panel and disconnect all three black wires and be sure they aren't touching anything. Turn the power back on and using a test light or meter determine which black wire is live. Turn the power back off and mark the hot wire with a pen, marker, or piece of electrical tape. Connect the wire you marked with a wire nut to one of the other two black wires. Turn the power back on. If the closet light comes on, that is the wire that you want to connect to one of the terminals of the switch. If the lights in the kitchen and bath now work, leave these wires connected together and connect the third wire to one of the switch terminals. Turn the power back off. While the hot wire and the wire for the kitchen might have both connected to the switch terminal, this is no longer allowed by code. Instead take another piece of wire of the same type and connect it to the hot wire and the kitchen wire with the wire nut and connect the other end to the other switch terminal. There should be a green ground screw terminal attached to the metal frame of the switch. Using a green or bare copper wire connect this to the ground wires in the switch box. Reinstall the switch and turn the power back on. Everything should be good now. If the fuse blows or the breaker trips, replace the switch.
Posted on Dec 23, 2008
  • 4 Answers
Call an electrician. You are clearly not qualified or knowledgeable enough to do this work, and you are putting your tenants lives and property in jeopardy.
Posted on Apr 26, 2009
How do I wire double elrctrical switches?
i assume both switches are single pole? How to wire depends on what wires you have in the box (i.e. the circuit they are in).
Aug 10, 2014 | Leviton White Double Wall Light Switch...
How do I hook up a Leviton Decora no 5601... I have a white, a red, and a black wire
Wiring is unclear without more information.
Question posted under 4-way switch.
Wiring sounds like 3-way switch is possible.
And Leviton 5601 is single pole switch.
Add a comment and say what load the switch controls. Load means light, fan, motor, etc.
Say if another switch controls same load.
And include what type of device you are replacing.
Include what screws and screw colors are on old device.
When you add a comment, it sends email, and I will respond to comment.
Sep 01, 2011 | Leviton 112-05604-2WS 15A 4-Way Decora...
I need to find leviton 1755 in brown
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Apr 30, 2011 | Leviton 1755 Triple Rocker Switch Decora
Installed Acenti by Leviton single pole switch and when in "off" position, there is a flickering of light on and off, its like a pulse... model AC201-1LW... the only thing i can think thats wrong...
No you are getting a backfeed from somewhere else...either the neutral is no connected properly or you have a bad ground...
It has nothing to do with the amp. rating of the switch..
heatman101
Apr 23, 2011 | Leviton Acenti AC201-1LW 20 Amp, 120VAC,...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Im replacing a switch to my garbage disposal when i turn the power on both circuits are hot my question is that the switch runs hot in off position and when i turned the power on and flipped the switch it...
What type of switch are you using? A single pole switch does not have a ground. There will be 2 screws, and it doesnt matter which one you connect the Line (feed) and the load (garbage disposal) too. With the switch disconnected only one wire will be hot.
Hope this helps,
Cheers
Jan 06, 2010 | Leviton 104-05611-2WS 15A Decora Single...
We just started getting shocked when we turn on some of our light switches never had this happen before it started hapening right after we had lost power does anyone know what might cause this? Thanks...
Angela
It sounds like a static electricity issue to me, and if so there are many products on the market to eliminate this. The most effective are anti-static carpet spray's that can be purchased from a local carpet dealer or supply. You can research other remedies on the web.
Tip: You can create an inexpensive anti-static spray by mixing laundry fabric softener with water 50/50 into a spray bottle. Lightly mist this spray on carpets and other surfaces to prevent static buildup.
Hope this helps
Good luck...
Feb 23, 2009 | Leviton 104-05611-2WS 15A Decora Single...
Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
Dec 13, 2008 | Leviton 104-05611-2WS 15A Decora Single...
Leviton 104-05611-2WS 15A Decora Single Pole Illuminated Switch with Ground Logo
120 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
