Question about Dell Ethernet Card Network Adapter
Dell 4700 Computer Integrated NIC Problem
I have a Dell 4700 Computer with an integrated Intel PRO/100 VE network card. My OS is Windows XP Home Edition.
When I plug my ethernet cable into the port, the connection is not detected. I installed a Linksys LNE100TX NIC card into my PC, left the ethernet cable plugged into the integrated Intel PRO/100, and then the network was detected on the Intel PRO/100.
I removed the LNE100TX NIC and the network was no longer detected. I reinstalled the LNE100TX NIC card and the network was again detected when connected to the integrated Intel PRO/100. I disabled the Linksys LNE100TX NIC, uninstalled the driver, powered down my PC and removed the Intel LNE100TX NIC from my PC. Powered it backup and the integrated NIC (Intel PRO/100) still detected my network. Great problem solved! NO!
I powered the PC back down and installed a sound card in the slot that the LNE100TX NIC was installed. Powered my PC backup and now no network connection detected again by the integrated Intel PRO/100 NIC. I powered my PC back down removed the sound card and reinstalled the Linksys NIC. Powered up, now the ethernet connection is only recognized when it is plugged into the Linksys card. The integrated PRO/100 won't recognize the connection at all.
If anyone can help I would really appreciate it. I would like to get my PCI slot back so that I can install a sound card.
Thanks, in advance for your help.
  • 88 Answers
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Posted on Jan 12, 2009
I lost my lan driver
The Dell E210882 motherboard has been used in the Dell Dimension 3000. Thus you can try the Dell site for the XP driver. Start here: http://www.dell.com/support/drivers/us/en/04/Product/dimension-3000 and expand the section for network drivers.
If you have a different OS, try the Intel site since the onboard LAN is the Intel Pro/100 VE hardware. The Intel generic drivers are here: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%C2%AE+Desktop+Adapters&ProductProduct=Intel%C2%AE+PRO%2f100+VE+Desktop+Adapter . Use the drop-down menus to select your OS and drivers if you want to shrink the list below (left-hand side).
If the on-board LAN has failed (it happens), get a PCI ethernet card. Then disable the on-board LAN in the BIOS. Usually that can be accessed by pressing Esc, F1, F2 or F10 on startup. There should be a splash screen telling you which key to press. If you get to the Windows login or Start Screen try again.
I hope this helps.
Jan 10, 2013 | Dell (E210882) Motherboard
Where can I find Acer 661fx-m71.2a ethernet controller? can anyone give me links?
http://download.cnet.com/intelv13-zip/3000-2112_4-195759.html
  • Intel 82557-based Integrated Ethernet PCI (10/100)
  • 82557-based Integrated Ethernet with Wake on LAN
  • Intel 82558-based Integrated Ethernet
  • Intel 82558-based Integrated Ethernet with Wake on LAN
  • Intel(R) PRO/100+ PCI Adapter
  • Intel(R) PRO/100+ Management Adapter
  • Intel(R) PRO/100+ Server Adapter
  • Intel(R) PRO/100 Network Connection
  • Intel(R) PRO/100 VE Desktop Adapter
  • Intel(R) PRO/100 VM Desktop Adapter
  • Intel(R) PRO/100 VE Network Connection
  • Intel(R) PRO/100 VM Network Connection
  • Intel(R) PRO/100 VE Desktop Connection
  • iSeries 2892 10/100 Ethernet Port
  • Intel(R) PRO/100+ Alert on LAN* 2 Management Adapter
  • Intel(R) PRO/100+ Alert on LAN* Management Adapter
  • http://download.cnet.com/intel82573l-zip/3000-2112_4-165111.html
  • if these arent right you will find ethernet drivers and more
  • http://download.cnet.com/2000-20_4.html
  • on the home page you should see a search tab just type in what you are looking for
    (be precise)but don
  • Oct 04, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
    I need a sound driver, ethernet controller for my ibm thinkpad r50
    Assuming that your Operating System is Windows XP I have given you the details to download the drivers. Visit the link: http://www-307.ibm.com/pc/support/site.wss/MIGR-53178.html
    Scroll down to Networking: Ethernet section
    Intel PRO/1000 MT Mobile Connection adapter (10/100/1000 Ethernet) - Click on 8 Feb 2007 - Build 135400 In the next page click on 7ira09ww.exe and download
    If your Network Adapter is Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) then click in the other link Build 94590 (Build 94590 supports models with Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) only. In the next page download 1urc13ww.exe
    Apr 26, 2011 | IBM ThinkPad R50e Notebook
    Where is the sound card located in a dell dimension 1100?
    The sound is integrated onto the motherboard in this model, it isn't a separate card.
    Jan 01, 2011 | Dell Dimension 1100 PC Desktop
    Windows 7 doesn't see network card after sleep
    Hello
    Go to control panel,system,device manager,network adapter,Right click on your adapter.
    Then properties,power management.uncheck all power saver and wake options.
    May 27, 2010 | Dell Ethernet Card Network Adapter
    Reinstalled Windows XP no ethernet card
    It seems that after re-installing windows you have missed the Driver installation for your hardware. If you have a disk (which reads Drivers and Utilities) that came with your computer, You can insert it in your CD Driver and select the Driver for Network adapter. If you do not have a disc, you can always visit the Dell's support site i.e.:support.dell.com and Get the drivers suitable for your hardware by selecting the model or Entering the Service Tag of your Dell computer.
    For your convenience I am providing below the link for Drivers for Dimension 4700 Desktop PC as you have mentioned.
    Intel (R) PRO/100 Driver for Dimension 4700
    Hope you find this information helpful.
    Your comments and ratings are highly appreciated. Please do not forget to leave your feedback and ratings.
    Thank you for choosing Fixya.
    Dec 15, 2009 | Dell Ethernet Card Network Adapter
    Home Computer Network Confusion
    it easy plug your big plug rg 45 cable from the 2010 into your port 1 on your router then buy more rg45 cable from comp store plug it into port 2 then into comp 1 plug another one into port 3 on your router and plug it into other comp. everything should work xp will pick up and install anything needed. have fun surfing
    Sep 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
    Network adapter not being recognized by pc
    you need to disable the old network card go to the computer setting (CMOS) and disqble the network card (you are having a hardware addressing conflict.
    Jul 01, 2009 | Computers & Internet
    Lost Ethernet on Win XP MCE upgrade
    Hi glycogenic open up the case and look for a motherboard model number on the motherboard (it could be anywhere) but sometimes in large print, then do a search with it on the net
    ie Ethernet drivers for (insert mobo number) running XP MCE 2005. or something similar.
    good luck with that
    Terry
    Feb 26, 2008 | ViewSonic NextVision M2000E PC Desktop
    Dell Ethernet Card Network Adapter Logo
    630 people viewed this question
    Alun Cox
