Question about HP LaserJet 1022 Printer
A white strip in the middle of a printed page
A white strip shows in the middle of a printed page from top to bottom. The rest of the page is good.
  • ajohns56 Jan 08, 2009
    HP 1022 printer: About 3 years old.
    Inever
    HP 1022 printer. About 3 years old. About $200.00
    I never had to change the toner cartridge.
    I cleaned the "pickup roller" (?). When I re-installed it and turned the printer on, there was grinding sound. I turned the printer off and saw some blacl powder inside. I guess I screwed up !!!
    I bought the printer at Staples. I called them and they don't repair printers. Staples gave me a phone number to call to have the printer repaired. Staples said they charge $100.00 just to look at it.
    PLUS the cost of parts and a "toner cartridge" about $70.00.
    FORGET IT !!!! I'm junking it !!
    I bought a HP P1006 laser ptinter for $100..
  • 89 Answers
You should first try a new toner. Ther may be something stuck inside the toner cartridge. You might also try cleaning out the inside to be sure there isn't something blocking the light flow. If it still continues to happen there may be a problem with the fuser unit.
Posted on Jan 08, 2009
Print shows white lines through the middle of photo
The laser beam is dimmed by leaking powder.
Open the top-cover.
Remove the drum-cartridge with the green handle.
Clean carefully the small glaa-strip deep down inside the printer.
Replace the drum-cartidge. Close the cover.
Problem solved.
Sep 08, 2013 | Konica Minolta magicolor 2430 DL Laser...
When I make a copy, I get a blank strip running from top to bottom near the middle of the page?
Do the lines show up when you make copies with the adf and the copyboard glass?If it shows up on both you may need a new OPC drum & cleaning blade.
Sep 02, 2011 | Minolta EP1031/1031F CS/PRO Copier
The printer is not printing all of the page. The first page usually prints nearly all of the page, subsequent pages less so. The paper is not being scrunched up, it's just not printing lines in the...
when you press ctrl+p for print there is a setting there by the bottom left which says "Print:" beside it check the check the list if it says "all pages in range"if not press it and then press the word
Nov 28, 2010 | Canon PIXMA iP1200 Photo Printer
Status idle + Test page onl shows top (reddish). Rest is blank.
Check that you're not out of "blue" and/or "black" ink.
For example, no "green" on the page means that the printer did not mix "yellow" and "blue".
Also, the "rest" of the test-page should be "black", if any black ink is available.
Jul 03, 2010 | Lexmark X2350 All-In-One InkJet Printer
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
Sustain pedal on Yamaha DGX not working
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Close the cradle latch.
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Thanks,
Aug 30, 2008 | HP LaserJet 2840 Printer
HP LaserJet 1022 Printer Logo
182 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
