Question about Dell Inspiron 6000 Notebook
DST Error (1000-0146) - Dell Inspiron 6000 Notebook
  • 1 more comment
  • Anonymous Feb 16, 2009
    Please help
  • Anonymous Apr 18, 2009
    for some reason it stops at 25% complete after runing chkdsk /r for me ... i dont know why? do you?
  • Anonymous May 03, 2009
    we thought it was the drive but were not sure. Thank you for your help. The drive would make terrible noise when loading and gave us an error each time.
  • 340 Answers
Hi there, and welcome to FixYa,
DST stands for Drive Self Test, if it fails the test it means your drive is failing.
1. Do you have access to a Windows CD?
If so you can try to boot to the recovery console and run chkdsk /r.
Hopefully you can get it to boot, backup what you need, - then replace the drive.
2. Another solution could bee, - a bit more aggressive,
Reinstall your OS.
3. or - it could just be an error that can’t be fixed. I would get a new disk, install my OS, set the other as slave, and get the needed files.
regards
Teis
Don’t forget to vote if this help you.
Posted on Dec 13, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
My daughter's computer had the same problem. I ran the chkdsk as suggested at the recovery console. It told me there was a problem in the boot sector. So I typed in 'fixboot'. It asked me if I wanted to overwrite the files in the boot sector. I typed "y" for yes and it fixed itself. It is now working like nothing was ever wrong with it.
Posted on Aug 03, 2009
My Dell Laptop is stuck in a continous loop. I can get to the boot screen using F12. However, no mater which option I choice (safe mode, recovery to last know good boot, etc); after pressing enter the quickly goes through the first part of the boot up then stops at the screen giving me the opions to "recovery of .......boot; safe mode etc. There is one blue screen that flashes by at the near end of the loop, but I can not read the information.
Appreciate your help.
Heather
Posted on Mar 20, 2010
pa1nkiller
  • 68 Answers
SOURCE: DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Posted on Aug 21, 2009
e-ware
  • 776 Answers
SOURCE: I am getting a dst short test failed error code 1000=0146
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Sep 10, 2009
Vaio Tech
  • 166 Answers
SOURCE: Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
try to change out the hard drive on the notebook whid a similar one the size of the hard drive can not be over 160 gb and reinstall windows if it work you may be loss your hard drive
Posted on Oct 10, 2009
  • 3940 Answers
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Posted on Jan 27, 2010
PuRaW
  • 8 Answers
SOURCE: DST Short Status Test Fail Error Code 1000 0146
DST (Drive Self Test) failed. this simply means that the drive is no longer stable. If you are unable to boot to windows or safe mode and this is the error you get you might need to do a low level format if you still want to use it or do a debug script then repartition and re-format the drive.
The Low-level partition - will reinitialize your drive to the factory settings.
Debug Script - removes DOS and non-DOS partitions on the hard drive. It also allows you to convert a drive from an incompatible partition structure to one that will work with FDISK.EXE such as, converting Linux partitions to MS-DOS partitions.
For you to use the Low-level format and to completely wipe out HDD data. Use the format software from http://www.killdisk.com, download the CD ISO image , burn to CD, ad boot from CD , the rest can be found in the menu.
In using the debug script use this :
Insert the boot diskette that contains the Debug command into the respective drive.
Restart the computer.
A black screen with Microsoft Windows® 95 Startup Menu will appear. Press the <5> key on the keyboard followed by the <Enter> key. The boot process will conclude with an A:\> prompt, followed by a blinking underline (cursor).
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Hope this helps to save your drive.
Posted on Feb 22, 2010
How resolev dst short test
Well, a DST error (Drive self Test) error means the hard drive is bad
Jun 11, 2014 | Dell Latitude D800 Notebook
Error message 2000-0151 on dell inspirion 1545
Hi.
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
Error 0303 short dst failed
Hi
This means a program file is missing. Just do a search of the file (short dst) on your search mechine locate and download it.
It should correct the error automatically when you restart.
Have fun!
Aug 03, 2011 | HP Compaq 6730s Notebook
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dell Latitude wil a DST short test fail. error
you are correct, time to replace the hard disk drive.
Jan 28, 2010 | Dell Inspiron 6000 Notebook
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Aug 16, 2009 | Dell Latitude D610 Notebook
Dst SHORT KEEP GETING THE BLUE SCREEN SO I RAN DELL TEST THAT SAID DST SHORT ?? I DO NOT HAVE ORGINAL OS DISK & UNABLE TO MAKE A COPY ERROR WITH DOWN LOAD??
DST = Drive Short Test.
Its called 90/90 Diags for hard drive. You need to contact Dell Tech because the hard drive needs to be replaced
Jun 05, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
7,876 people viewed this question
Clive
Clive
Alun Cox
