Question about Microwave Ovens
I have owned as many as 6 Sharp convection Microwaves, they have all suffered the same fate. The timer when in convection stops at approx 5min in this time it has not heated hot enough and each time is reset it will work again for another 5min. If on duel power it stops on convection but works on microwave. It cost about $80 plus to repair depending on who you take it to. I have 4 units with this problem at this moment. My Sons, sisters a rental as well as mine. Can you help identify the part that causes the problem. Can you inform Sharp as I beleive they should have attended to this issue but the same moduel is in different models. Yours Sincerely Terry Dowsett
  • Microwave Ovens Master
  • 9,098 Answers
"Convection cycle runs 4 minutes and 15 seconds then shuts down."
In most cases, this is a bad thermistor, but it may also be loose wiring, or a problem on the control panel.
The thermistor should be on the top of the chassis and it will look like one of the attached drawings.
You will have to remove the outer cover of the oven to get to it.
THERMISTOR TEST
Room Temperature 68°F(20°C) - 86°F(30°C)
Resistance Approx. 350k ohms - 155k ohms
(The higher the room temperature, the lower the resistance, and vice-versa).
If the meter does not indicate above resistance, replace the thermistor.
Also, if the thermistor is caked with grease, or it's rusty, it will need to be replaced.
If it has a broken lead, it cannot be repaired unless you spot weld orbraze it, and if you get it too hot, it will be destroyed.
To find the thermistors, you can visit Sharp'sAustralian support siteand click on the "Spareparts Outlets" link under "Frequented Resources".
(If you're not in Australia, please write back and let me know where you are!)
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Posted on Dec 15, 2008
Is the sharp above range microwave model r-1871t recirculating?
According to the Sharp product site, http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models/R1871.aspx , the R-1871 is a convection and microwave oven. The manual describes using the convection oven feature on page 18 (page 20 of the PDF). The direct link to the manual is: http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R1872.pdf . The convection button is on the top left in the middle group of buttons. You use the numeric power level buttons to set the oven temperature. When you program convection cooking, the 1 button will bring the oven to 100 degrees F. The 6 button gets the oven to 350 degrees F.
I hope this helps.
Sep 18, 2015 | Sharp Microwave Ovens
Sharp jet convection double grill
Looking at other answers below your question on the page that i am viewing anyways. It appears that Sharp convection microwaves or Sharp microwaves in general seem to have an ongoing problem of that sort. The solution is to replace the main circuit board.
Nov 09, 2013 | Microwave Ovens
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Dim Display Panel on Sharp Convection/Microwave R-1851
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
Mar 13, 2009 | Sharp Microwave Ovens
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
I have R-9X58 timer that stopa @ 5min when in convection mode
THERMISTOR TEST
If it has a broken lead, it cannot be repaired unless you spot weld or braze it, and if you get it too hot, it will be destroyed.
To find the thermistors, you can visit Sharp's Australian support site and click on the "Spareparts Outlets" link under "Frequented Resources".
Dec 13, 2008 | Sharp R-1870 Convection/Microwave Oven
Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
